ChangDriver
Posted: Sat Oct 10, 2009 12:12 pm Post subject: P-lead for the Tach |
Bob:
When wiring a tach that uses the p-lead for its signal, can you help me with:
1) would it be best to run new shielded wire from the mar to the tach vs trying to tap the p-leads off the mag switch?
2) is 20 AWG shielded wire the recommended wire size for the p-lead (that is what I see in your book)?
Thanks in advance,
Craig
Posted: Sat Oct 10, 2009 6:09 pm Post subject: P-lead for the Tach |
At 03:13 PM 10/10/2009, you wrote:
<capav8r(at)gmail.com>
Bob:
You can tap the signal at either end but at the mag switch
terminal end makes the most sense. Your installation instructions
for the tach may also recommend putting a resistor in series
with the signal lead at the switch so that a faulted wire
in the tach wont kill the mag.
| Quote: | 2) is 20 AWG shielded wire the recommended wire size for the p-lead
20AWG or larger is the general rule for any wires that run
out to the engine nacelle . . . for mechanical robustness.
22AWG or even 24AWG would be electrically capable of controlling
mags . . . but I don't think I've ever seen them wired with less
than 20. Some older airplanes even had 18AWG.
22AWG shielded between the mag switch and tachometer will
be quite sufficient.
( -Thomas Paine 1776- )
