DuaneFamly(at)aol.com Guest
Posted: Sun Oct 11, 2009 8:38 pm Post subject: Mod 73 Problem |
Good day to All,
Well, I finally got around to doing Mod 73 on a yet-to-fly XS kit and the first tailplane went well but after pulling off the second I found that the TP6 sleeve has, somehow, rotated and now shows shiny metal in the hole of the fiberglass layup previously done for the top PIP pin insertion hole. My guess is a rotation of about 20 degrees. Am I now going to have to tear into both top and bottom access hole in order to rebond this sleeve to the outboard rib? Anyone else have this problem? I thought that I had used a sufficient amount of grease on the torque tube but still had a little problem removing the second tailplane.
Thanks in advance.
Mike Duane A207A
Redding, California
XS Conventional Gear
Jabiru 3300A
Sensenich R64Z N
Ground Adjustable Prop
