QB Fuselage Question
Kelly McMullen
PostPosted: Thu Oct 15, 2009 10:55 am    Post subject: QB Fuselage Question Reply with quote
I'm at the dreaded front floor removal debate. Adding to the anxiety
is the fact that the floorboards to side skin rails mismatch the holes
by 1/4 to 1/2" and I see no give at all in the side skins, nor the
floor ribs to close that gap. I'm leaning towards removing at least
one gear weldment and floor board to see what is there and to install
insulation. Not to mention that the 9 pop rivets holding the floor in
are button heads, not flush, even though the skin is dimpled for
flush.
Thoughts?
Kelly McMullen
A&P/IA, EAA Tech Counselor
KCHD
Tim Olson
PostPosted: Thu Oct 15, 2009 11:19 am    Post subject: QB Fuselage Question Reply with quote
The rivets are just temporaries, but not sure what to tell you about
the mismatch.
Tim Olson - RV-10 N104CD
flush.
Thoughts?
Phil.Perry(at)netapp.com
PostPosted: Thu Oct 15, 2009 11:57 am    Post subject: QB Fuselage Question Reply with quote
Hey Kelly,
I just went through this and I'd encourage you not to do it. It's is a
royal PITA and I'm sorry I did it.
I fixed the alignment issues by starting to cleco in the center of the
floor plan and working my way to the sides. Everything aligned just
fine.
A word of advice though. Check the torque values on those AN3 bolts.
I'll bet they're torqued up to 85 inches. I replaced the bolts that I
could easily replace and I replaced nearly all of the nuts and retorqued
to 25 inches.
But I wouldn't wish a main gear mount removal on my worst enemy. Never.
Phil
Jim Berry
PostPosted: Thu Oct 15, 2009 12:23 pm    Post subject: Re: QB Fuselage Question Reply with quote
Kelly,
I don't know about the gap, but there is no other reason to remove the floor boards. After drilling out the temp rivets you will be able to pull up the aft edge of the floor boards, without removing it altogether. That will give you enough access to snake a hose forward to vacuum out whatever the QB guys left for you. I was also able to insert pieces of insulation and slide them forward.
Jim Berry
40482
N15JB
dlm46007(at)cox.net
PostPosted: Thu Oct 15, 2009 12:38 pm    Post subject: QB Fuselage Question Reply with quote
Agreed. But until I spoke to Vans in 2005 about their failure to install the
4 nut plates for the forward gear mount supports. The front floors and gear
mounts had to be removed to install these nut plates. After 2005 the nut
plate for the forward gear mount support have been installed by the QB,
eliminating the requirement to remove the gear mounts and the front floors.
Ditto for the rear floors; suggest not removing the rear floors; no need.
Kelly McMullen
PostPosted: Thu Oct 15, 2009 12:54 pm    Post subject: QB Fuselage Question Reply with quote
The rear floors come off easy, the pop rivets were wrong and had to be
drilled anyway. I'll take the suggestion to just pry one corner on the
front floorboards. I'll try clecoing the front floor together, but
sure looks like a serious mismatch.
Kelly McMullen
KCHD
Kellym
PostPosted: Thu Oct 15, 2009 4:13 pm    Post subject: QB Fuselage Question Reply with quote
You win the prize for the best advice. Got one floor board up this
afternoon. Also managed to find that I could get the floor board clecod
except for the rear outer two holes...which appear to not have been drilled.
Jim Berry wrote:
Kelly,
Jim Berry
40482
N15JB
Kelly McMullen
KCHD
dmaib(at)mac.com
PostPosted: Thu Oct 15, 2009 4:23 pm    Post subject: QB Fuselage Question Reply with quote
I seem to remember that the pop rivets in the front and rear floors
are temporary and are supposed to be removed and replaced with pop
rivets called out in the plans. I agree with Phil that taking the
gear weldments/front floors out is not worth the grief. You will be
undoing work that you paid to have done at the QB factory.
David Maib
40559
Flying
install the
and gear
the nut
QB,
floors.
need.
johngoodman
PostPosted: Thu Oct 15, 2009 6:53 pm    Post subject: Re: QB Fuselage Question Reply with quote
You paid a lot for the QB. If you are really terrified of what you might find under the front floors, buy a fiber optic scope and look. There are lightening holes behind every space located at the aft end under the seats.
Vacuum hoses and magnets also work well.
John
Kellym
PostPosted: Thu Oct 15, 2009 7:17 pm    Post subject: QB Fuselage Question Reply with quote
What good kit hasn't been assembled and disassembled at least 4 times?
Somehow, half dozen screws and temporary pop rivets aren't a big deal to
be able to install some good insulation down there, to help keep cabin
noise tolerable.
John
#40572 QB Fuselage, wings finished. Finish Kit progressing. Engine &amp; Panel delivery soon.
N711JG reserved
http://forums.matronics.com/viewtopic.php?p 68168#268168
Kelly McMullen
KCHD
Jim Berry
PostPosted: Thu Oct 15, 2009 7:21 pm    Post subject: Re: QB Fuselage Question Reply with quote
I will second John's recommendation re a fiber optic scope. See the multiple postings on the Aerolectric list about the Harbor Freight unit. I bought one on sale for $100 and have used it many times. It is a hair too big to slip through a spark plug hole though. I am even thinking about doing my own colonoscopy with it. Probably would not have to worry about anyone pilfering it after that.
Jim Berry
40482
N15Jb
johngoodman
PostPosted: Thu Oct 15, 2009 7:34 pm    Post subject: Re: QB Fuselage Question Reply with quote
noise tolerable.
Ah, my favorite subject. A good insulation. Try this:
Abesco FP 200. I don't have an interest in it other than I like it and use it. Here is a place to start your research:
http://cableorganizer.com/abesco-fire-rated-foam/
John
PostPosted: Thu Oct 15, 2009 7:34 pm    Post subject: QB Fuselage Question Reply with quote
Hey Kelly,
One other thing I did is replace the AN515-8R8 screws on the front of
the seat covers with NAS1801-08-8 structural hex head screws.
The head is a little smaller than the kit provided screws, but I like
the ability to use a 1/4" nut driver, socket, wrench, or screw driver
for removal. That bottom one that is the most inboard is a ******....
Not anymore though. Smile
Phil
n223rv(at)wolflakeairport
PostPosted: Fri Oct 16, 2009 2:14 am    Post subject: QB Fuselage Question Reply with quote
We removed the mounts on my buddies -10. Cleaned, primed, and
insulated under the floors. Yes the holes were hard to get back lined
up, but you can do it. It isn't nearly as hard as the fiberglass you
will soon find.....
On Oct 15, 2009, at 11:14 PM, Kelly McMullen <kellym(at)aviating.com>
times? Somehow, half dozen screws and temporary pop rivets aren't a
big deal to be able to install some good insulation down there, to
help keep cabin noise tolerable.
> John
> N711JG reserved
Kelly McMullen
PostPosted: Mon Oct 19, 2009 6:31 pm    Post subject: QB Fuselage Question Reply with quote
Funny you mention work paid to be done in the Philippines. Phil and I
have exchanged squawk lists on our QB fuselages. With only a few
exceptions they were identical. Looks like I will have to drill out
all the mid fuselage longeron rivets (F-1046) to do countersinking
that wasn't done, to trim the baggage door seal angle, and drill out
some of the F1013 left longeron to trim it to length without damaging
the skin. Clearly the QA/QC of the old facility was not transferred
to the new Philippine facility. Hopefully Vans hears this loud and
clear. More when I get a response from them.
On Thu, Oct 15, 2009 at 5:19 PM, David Maib <dmaib(at)mac.com> wrote:
I agree with Phil that taking the gear weldments/front
floors out is not worth the grief. You will be undoing work that you paid to
David Maib
40559
Flying
Kelly McMullen
KCHD
Bill Cannon
PostPosted: Sat Oct 31, 2009 5:17 am    Post subject: Re: QB Fuselage Question Reply with quote
My QB fuse came in the container after Phil's. I have some of the same issues with the longerons and torques but the floor panels seem lined up.
A couple of things I have come across in the past few days while inspecting and checking off the steps.
1. The bottom aft skin was drilled and dimpled where the F-1006B bulkhead and tailcone bottom skin are supposed to be match drilled to it. I talked to Vans and was given two options.... flatten out the dimples and match drill as per instructions or trust the pre punches are lined up correctly. I have trusted the pre punch in the past when replacing a skin on an elevator and everything worked out fine by just drilling the holes in the skin to size and dimpling. I am thinking I will just drill the tailcone by itself, dimple it and the put it together with the holes that are already done on the fuselage.
2. The inboard and outboard forward seat rail supports were riveted to the bulkheads(F-1043A L&R) using AN470 rivets instead of 426s. 470 is correct for the bottom 4 rivets but the top two need to be 426s to get the F-1043D to lay flat on the front to the seat bottom assembly. Since they were right at the edge of the front panel I cut notches in the panel to allow the 470s to remain without pushing out the panel. There are already holes or notches where bolt heads protrude so I saw no problem in doing this. It's somewhat of a puzzle getting the panel off without removing the gear bracket but it can be done.
3. The F-1004M wear strip was not installed by QB and no parts provided in kit. Vans is sending the parts
4. The flap actuator brackets (F-1066B L&R) are cut into left and right. Right is installed now and Left is retained for attaching the actuator. Right is riveted to the plane and the left is in the Phillipines. A new part is coming from Vans.
5. I remember reading somewhere that the QB process involved priming. Either the primer they are using is clear or it was not done. The metal is nice and greasy though Shocked
Just thought I'd add to the list to help anyone else out there trying to get through the QB check.
bill
Kellym
PostPosted: Sat Oct 31, 2009 5:52 am    Post subject: QB Fuselage Question Reply with quote
Yeah, the "primer" allegedly is clear with no solids content. How this
protects the metal is a mystery to me. The metal appears to have been
scuffed. Whatever the coating, it must be very thin. There must be a big
collection of snap bushings in the Phillipines as none got in the QB nor
the parts kit. It is a shame that Van's apparently is depending 100% on
builders to do QC.
5. I remember reading somewhere that the QB process involved priming. Either the primer they are using is clear or it was not done. The metal is nice and greasy though [Shocked]
bill
http://forums.matronics.com/viewtopic.php?p 70217#270217
Kelly McMullen
KCHD
PostPosted: Sat Oct 31, 2009 2:02 pm    Post subject: QB Fuselage Question Reply with quote
It has solids, it just doesn't have any pigment (like is required in the states).
To test the film for yourself, drop a factory primed piece into alumaprep for 5 min and pull it out.   You'll see the coating beginning to wrinkle and peel.  The aluminum will barely be touched and you will have to peel the primer off like a banana.
After seeing it with my own eyes, I realized I was worried about nothing. And actually felt pretty stupid when I realized how much trust I put in my perception of effectiveness because of pigment.
I'm not worried at all about their choice of primers now.  Give it a shot for the peace of mind.
Phil
Bill Cannon
PostPosted: Sun Nov 01, 2009 7:18 am    Post subject: Re: QB Fuselage Question Reply with quote
will do. At this point it would be easier to move to a dry climate than prime it anyway. Very Happy
