Fuel line fittings
mjpienaar(at)shaw.ca
PostPosted: Tue Oct 27, 2009 4:43 pm    Post subject: Fuel line fittings Reply with quote
How do I shorten the mounting distance between 2 items ( my filter and fuel pump) both with male AN6 fittings. The shortest length of solid aluminum tube I can make up is +/- 2 inches. It would also help if I can get an elbow with a female AN fitting but that seems not to be available. If I bend solid aluminum tube the radius and the tail needed for the fitting takes a lot of space.
Mike
bakerocb
PostPosted: Tue Oct 27, 2009 5:53 pm    Post subject: Fuel line fittings Reply with quote
10/27/2009
Hello Mike, It is a bit difficult to envision your set up. Are these two
items in line or mounted side by side on a bulkhead? I have some potential
solutions in mind, but it would be helpful if you could take a picture with
a digital camera and post it to this list. A direct copy to me would also
expedite things.
There are many kinds of fittings beyond those sold by Aircraft Spruce -- I
am sure that there is a solution. Check out part numbers 934106, 915106,
921106, 981506, and 983206 on this web page just to get some ideas flowing:
http://www.anplumbing.com/shop/index.php?shop=&dept=Aluminum
OC
PostPosted: Tue Oct 27, 2009 8:40 pm    Post subject: Fuel line fittings Reply with quote
Thanks for your help OC, I'm afraid there are no photo's yet, I was just
laying the parts out and would like to keep the fuel filter in the wing well
outside the fuselage to reduce spillage if I ever change or clean it if
that makes sense.
The parts you mention (934106, 915106, 921106) appear to be exactly what I
am looking for.
Mike
