		mullokintyre
				 Posted: Wed Nov 04, 2009 6:17 pm    Post subject: RV-List Digest: 7 Msgs - 11/03/09 |
				"Ralph E. Capen" SAID
  	  | Quote: | 	 		  .  I was told that the engine
 should not be attached as the road bounces would cause damage.
 Ralph
 Wow, all that bouncing around taxiing on rough strips, t
 hose multiple landings I often do,
 the  rollouts on  gravel strips etc
 must be doing a lot of damage is this theory is true!
 Sometimes you can't believe everything you are told.
 Mick the skeptic
  |  | - The Matronics RV-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		dale1rv6(at)comcast.net Guest
				 Posted: Fri Nov 06, 2009 3:22 am    Post subject: RV-List Digest: 7 Msgs - 11/03/09 |
				I think only half the idea was expressed. The real concern would be to mount
 the engine on a temp basis, with bolts to the firewall NOT torqued properly.
 Then it could bounce around and hammer the mount area. Similar lesson to the
 story of the canopy that was not secured. Same could happen if wings were
 not properly secured.
 Dale
