		4RCSIMMONS(at)comcast.net Guest
				 Posted: Mon Nov 02, 2009 10:12 am    Post subject: A little Help! Muffler -Heat Muff |
				Hey folks,
 I would like to make my own heat muffs for carb heat and cabin heat.
 Dimension are not much of an issue however, can someone tell me what thickness Stainless steel I should use?
 From some reading I see it is 304 Stainless that is used and in some cases is Aluminum. Does it matter?
 Yes I am trying to save a buck, but want to make it only once.
 Rich
  |  | - The Matronics Zenith601-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		psm(at)att.net Guest
				 Posted: Mon Nov 02, 2009 11:04 am    Post subject: A little Help! Muffler -Heat Muff |
				Hi Rich,
 I wouldn't use aluminum for this purpose.  The exhaust gasses get
 around 1400 degrees F, and if I remember correctly aluminum melts
 around 1000 degrees F.  You might wind up with a puddle of aluminum
 in your engine compartment.
 I don't have easy access to my airplane right now, but I would guess
 the thickness of the muffs from the Jabiru FWF was around .020 or .025 inches.
 Paul
 XL awaiting engineering changes
 At 10:11 AM 11/2/2009, you wrote:
  	  | Quote: | 	 		  Hey folks,
 Rich
		Gig Giacona
				 Posted: Mon Nov 02, 2009 12:02 pm    Post subject: Re: A little Help! Muffler -Heat Muff |
				 	  | psm(at)att.net wrote: | 	 		  Hi Rich,
 I wouldn't use aluminum for this purpose.   |
 Somebody better tell Aircraft Spruce. http://www.aircraftspruce.com/search/search.php?query=heat+muff&search=1
 CESSNA TYPE HEAT MUFF
 Heli-arc welded aluminum muff with rustproof stainless steel fins for clamping to stack.
 HOMEBUILDER'S HEAT MUFFS
 These superior quality heat muffs are made entirely of 6061 and 5052 aircraft grade aluminum, offset from the center to clear the close cowling of most homebuilts.
601XL Under Construction
				 Posted: Mon Nov 02, 2009 4:08 pm    Post subject: A little Help! Muffler -Heat Muff |
				Rich,
 I assume you're talking heat-muffs averse mufflers here.  For conveying
 heat from the muffler to the cabin, aluminum is fine for a heat muff.
 I used .025 and wrapped it to a hinge joint. If you're doing mufflers,
 you need a .025 or better stainless as the temps recorded 3 inches or so
 from the exhaust are near 1350 degrees.  You'll probably make two sets
 to get it exactly right, so don't scrimp on bought material.
 Rich Simmons wrote:
  Hey folks,
  Rich
				 Posted: Tue Nov 03, 2009 6:16 am    Post subject: A little Help! Muffler -Heat Muff |
				Larry,
 Correct, not the muffler! Just the Muff on the outside of the muffler can for cabin heat
 The flanges for the scat tubing themselves from ACS are aluminum and with continuous air flow aluminum should be ok.
 Not trying to be cheap just frugal. I can make a few things and it saves hundreds of dollars if not more.
 Thanks for the comments.
 Rich
				 Posted: Tue Nov 03, 2009 6:46 am    Post subject: A little Help! Muffler -Heat Muff |
				Rich,
 I should have pointed you to the construct that I did. It works well and
 I've only got 3/8 to 1/2-inch clearance from the muffler
 for airflow. No baffles inside either. Just the hard rings at the ends
 to support the wrapper.
 http://www.macsmachine.com/images/subaruengine/full/muffports3.gif
 http://www.macsmachine.com/images/subaruengine/full/muffports2.gif
 http://www.macsmachine.com/images/subaruengine/full/heatmuffler.gif
 http://www.macsmachine.com/images/subaruengine/full/exhaustwrapsilver.gif
 Good luck,
 Rich Simmons wrote:
  Larry,
  can for cabin heat
  Rich
		bryanmmartin
				 Posted: Tue Nov 03, 2009 9:14 am    Post subject: A little Help! Muffler -Heat Muff |
				Since you have a water cooled engine, why didn't you just run the
 bypass lines through a heater core in the cabin? That would just about
 eliminate any risk of carbon monoxide in the cabin from an exhaust
 leak. You would also have a smaller penetration through the firewall.
 Bryan Martin
 N61BM, CH 601 XL,
 RAM Subaru, Stratus redrive.
 do not archive.
  _________________ --
Bryan Martin
do not archive. |
				 Posted: Tue Nov 03, 2009 1:28 pm    Post subject: A little Help! Muffler -Heat Muff |
				Bryan,
 I could easily take the heat directly from the radiator into the cabin,
 but the heat muff keeps hot air out of my belly mounted radiator which
 improves
 engine cooling by 7-degrees F.  The 1-1/2-inch hole in the firewall is
 no real penetration nor worry as far as fireproofing goes. Carbon
 monoxide is also
 a non-issue as it's monitored at the panel. I get a 20-degree lift in
 near freezing temps from my existing setup, so it works for me and is
 low maintenance.
				 Posted: Wed Nov 04, 2009 4:54 am    Post subject: A little Help! Muffler -Heat Muff |
				Larry!
 Thanks for the pics!
 They support the concept I have in mind. Combining the pics from the Zenith setup and yours I smell success.
 I  think I will make the first one out of heavy card stock and then try and fold the actual metal once.
 Are you aware of a good source of spinners! I see the Cummins from Australia that Jabiru uses. Are there any others you can recommend for home built application?
 Thanks again!
 Rich
				 Posted: Wed Nov 04, 2009 6:58 am    Post subject: A little Help! Muffler -Heat Muff |
				Rich,
 I obtained my spinner and plates from UHS Spinners, PO Box 135, Markham,
 Ont. L3P 3J5
 Phone 905 640 1534
 Email uhs(at)istar.ca
 They make 8,9,10,11, 12 and 14 inch spinners. These are a fiberglass
 product that is quite good.
 Larry McFarland
 Rich Simmons wrote:
 [quote] Larry!
  Thanks again!
  Rich
