ChangDriver
Posted: Tue Nov 03, 2009 6:40 am Post subject: Header Tank Leak |
When plane was topped off the other day (first time in two months as plane has been in shop for some rewiring), there was a strong smell of fuel in the cockpit. Investigated and the header tank fitting on the right side (where wing tank line enters header tank) has heavy blue staining on it. Before defueling the plane to correct, is this a dry fitting, are there seals, any type of sealer to use? Also, how do I get the blue stain off places where fuel leaked?
Craig
Posted: Tue Nov 03, 2009 8:04 am Post subject: Header Tank Leak |
Craig,Call me before you try to remove the fitting from the header tank. If you do it incorrectly you will twist the flapper off the valve which is on the inside of the loose fitting.
Doug
On Tue, Nov 3, 2009 at 6:40 AM, Craig Winkelmann <capav8r(at)gmail.com (capav8r(at)gmail.com)> wrote:
| Quote: | --> Yak-List message posted by: "Craig Winkelmann" <capav8r(at)gmail.com (capav8r(at)gmail.com)>
Craig
http://forums.matronics.com/viewtopic.php?p=270765#270765
="_blank">www.aeroelectric.com
ooks.com" target="_blank">www.buildersbooks.com
et="_blank">www.homebuilthelp.com
le, List Admin.
rget="_blank">http://www.matronics.com/Navigator?Yak-List
Maybe life is not the party that we were expecting,
but in the mean time, we're here and we can still dance....."
Douglas Sapp
Doug Sapp LLC
18B Riverview Road
Omak WA 98841
PH 509-826-4610
Fax 509-826-3644
ChangDriver
Posted: Tue Nov 03, 2009 1:05 pm Post subject: Re: Header Tank Leak |
Thanks Doug, as always it was good to talk to you. You wanted me to make sure I did not have the tank upside-down with the flappers hanging open when trying to retighten the fitting.
I was hoping to not need to remove the header tank at all. I have looked at Book 2, Figure 1-11 and there is no detail of the fitting and flapper valve.
Any other insight about how to tighten/seal this connection would be a big help.
Craig
wlannon(at)persona.ca Guest
Posted: Tue Nov 03, 2009 8:50 pm Post subject: Header Tank Leak |
Hi Craig;
You can't just "tighten the fitting". The flapper valve hinge must remain
exactly at the top to provide proper operation. There is a mark on one flat
of the nut to indicate the top position.
You will need to remove the valve assy. This is where Doug's caution comes
into play. It may be possible to remove with the tank installed but you
need to turn carefully by hand to determine if the flapper has opened and
hung up. If so you must remove the tank.in order to remove the valve.
Clean up, check operation and re-install with a new gasket a little thicker
than the one you removed. The objective is tight - with the hinge exactly
at the top. Not as easy as it sounds, you may need a variety of gaskets of
varying thickness.
An AN900-29 copper crush washer may do the job. Use Parker Seal-Lube (or
Fuel-Lube) on the threads and the gasket.
I usually make an index mark on the nut opposite to the Chinese mark so that
it is easier to see when tightening.
Good luck
Walt
ldakos(at)bigpond.net.au Guest
Posted: Wed Nov 04, 2009 12:53 am Post subject: Header Tank Leak |
Craig
Be careful if you are going to take fittings off tank the flapper valve will
flop over if you just screw it out, I made a little device to hold it in
place when I had the same problem as you.
I can send you a pic.
Regards Lou
ChangDriver
Posted: Wed Nov 04, 2009 10:03 am Post subject: Re: Header Tank Leak |
Lou:
I'm sure we'd all like to see what you created!! Please post a pic.
Also, it has been suggested to cut in a fuel shutoff valve, that can be safety wired open, in each fuel feed line. This would remove the need to pump fuel out of the plane next time the header needs service. What valve have others put in for this purpose.
Thanks for the advice,
Craig
Posted: Wed Nov 04, 2009 1:21 pm Post subject: Header Tank Leak |
Craig
I tried to post some pics but couldn't" so I sent them to Doug and asked him
to forward on to you.
Lou
