Allen Fulmer
Joined: 10 Jan 2006 Posts: 79 Location: Alexander City, AL
Posted: Sun Nov 08, 2009 6:43 pm Post subject: Failure Detection and Annunciation question |
Was reviewing your article: http://www.aeroelectric.com/articles/Failure_Detection_and_Annunciation.pdf
I want to annunciate the failure of a 12v scavenge pump to draw current. You mention such a circuit being used on a heated pitot but I was wondering if it mattered if the load was a pump motor? Full load would be approximately 5 amps and it needs to be running whenever the engine is running. I figured the LED would come on whenever I put power to the ECU and Ignition and would quickly go out if the scavenge pump was pulling power as it should. Thus, even if I “forgot” to flip the switch for the scavenge pump, the LED would illuminate until I did AND the pump was pulling power.
Any problem with a motor as opposed to a resistance load? Any other things I should consider?
Thanks.
Allen Fulmer
RV7 Eggenfellner Turbo normalized 6 cyl.
Finishing up the wiring
_________________ RV7 QB Fuselage
Eggenfellner H6 on orde
N808AF reserved
Alexander City, AL |
