FlyboyTR
Joined: 04 Nov 2006 Posts: 215 Location: Mobile, Alabama
Posted: Mon Nov 09, 2009 12:30 pm Post subject: Alternator Drive Coupling Failure |
My engine is an IO-240. I am now on my third Alternator Drive Coupling. This part (635796) is used on many different TCM engines. My engine was originally installed new from TCM. In 2006 and at 271 hours the original coupling failed. The cost of a new TCM coupling was $1,600 at that time. I replaced it with a rebuilt coupling for $450.
Now…254 hours later, the coupling has failed again. New cost is 2K, rebuilt is $525. My engine has to be removed to access the alternator…so this is not only a gross inconvenience…it’s also a costly little part that has a history of premature failure.
TCM tells that it is designed to fail to protect the engine and that failure is normal. OK…THANKS! My alternator has not failed/locked up! However, the couplings continue to fail. My average amperage load is about 6 amps (not much work for a 60 amp alternator). I am typically not switching on/off high amperage loads.
This is a link to my original thread on this problem. There are pictures of the original failed part at the bottom on the thread. http://forums.matronics.com/viewtopic.php?p=77593
Does anyone have any suggestions as to why these parts continue to fail? Is there another alternative? Thanks
Travis
| | - The Matronics Continental-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
_________________ Travis Rayner
Mobile, AL
Skystar Vixen, N-789DF
Continental IO-240, Prince P-Tip Prop
ADI-II Autopilot
AnyWhereMap Navigation with weather
www.enotam.net (My Flying Info Website) |
