mhubel
Posted: Mon Nov 09, 2009 8:25 am Post subject: The real work of the update on the CH601XL |
I have been looking at the drawings posted by Zenith. It would appear that to implement these changes one must remove all the rivets from the top of the wings and effectively completely dis-assemble the center consul and wing spar area in the fuselage. While building the plane was interesting, doing it half again might be a bit much. It looks like this is a 150-200 hour "update" assuming no problems are encountered. This significantly dwarfs the cost of any kit.
AMD says this is to be done by a licensed mechanic on their planes. That would be at least a $20K update. Am I missing something?
If not, might an engine and radios be worth anything?
_________________ Mark Hubelbank
N708HU
CH601XL
Jabiru 3300
Rotec TBI 40-3 carb
Sensenich ground adj prop.
240 hr TAF
Pictures at photo.hubbles.com |
psm(at)att.net Guest
Posted: Mon Nov 09, 2009 9:17 am Post subject: The real work of the update on the CH601XL |
Hi Mike,
I agree with your basic logic, but I think you have overestimated the
time to do the updates. Of course, we haven't yet seen all the
updates, so we are both a bit premature.
If you have assembled this stuff yourself, and get all the materials
and parts in their expected condition from ZAC, I think you could do
all this stuff in a week or two of full time effort. If you haven't
yet reached this point in construction then the changes add even less
effort. Of course, scratch builders will need more time to obtain
materials and prepare parts similar to the factory kit parts.
The people I feel the most empathy for are the ones who have
purchased an already built experimental Zodiac XL. They will have
few great choices about how to get the changes done.
The wing/carry through/seat modifications shown in the posted
drawings do involve removing a lot of rivets and replacing them along
with additional parts. The alignment, drilling, deburring, and other
steps on existing parts are already done and don't get changed. Once
you get some practice, drilling out these rivets only takes a few
seconds, maybe a minute, each.
For anyone who wants my technique, I drill rivets just skin deep
starting with #40 drill. Then I continue with #30 and #20 if needed
until the head pops off. Then it is just a matter of removing the
stem from the hole with either the appropriate drill or a punch and
mallet. It really is faster to do then describe if you don't count
time for changing drill bits. If you do a whole bunch of rivets at
once then the drill changing time becomes trivial. The other little
pointer is after you get all the rivets removed from the skin you
might want to find all the remains and remove them from the wing
before reclosing it.
For a mechanic who is not familiar with this construction method and
doesn't have the special tools like the rivet setter this could
indeed take 200 or more hours. Just a wild guess on my part: This
might justify returning the plane to AMD for modifications. That may
be what the writers of the FAA document had in mind when they
mentioned ferry permits.
One part of this you didn't include (I think) is possibly repainting
the wings. This could indeed be a big expense.
Paul
At 08:25 AM 11/9/2009, you wrote:
Mark Hubelbank
N708HU
jmaynard
Joined: 27 Feb 2008 Posts: 394 Location: Fairmont, MN (FRM)
Posted: Mon Nov 09, 2009 10:43 am Post subject: The real work of the update on the CH601XL |
On Mon, Nov 09, 2009 at 08:49:41AM -0800, Paul Mulwitz wrote:
| Quote: | I agree with your basic logic, but I think you have overestimated the time
to do the updates. Of course, we haven't yet seen all the updates, so we
I'm told to expect about 80 hours A&P labor to do the upgrade for my
airplane. AMD is very strongly recommending that the upgrade be done at the
factory for AMD aircraft.
Jay Maynard, K5ZC, PP-ASEL, CFI-SP http://www.conmicro.com
http://jmaynard.livejournal.com http://www.tronguy.net
Fairmont, MN (KFRM) (Yes, that's me!)
AMD Zodiac CH601XLi N55ZC http://www.tronguy.net/N55ZC.shtml
_________________ Jay Maynard, K5ZC
AMD Zodiac XLi N55ZC |
mhubel
Posted: Mon Nov 09, 2009 11:55 am Post subject: Re: The real work of the update on the CH601XL |
I figure one takes any personal estimate and double it to get to reality. That is how I got 200 hours.
Even assuming we do all this. will anyone write insurance for it after? That is not at all clear.
Anyone want an engine, and radios with a big metal bracket attached?
N708HU
CH601XL
Jabiru 3300
Rotec TBI 40-3 carb
240 hr TAF
