MichaelGibbs(at)cox.net Guest
Posted: Mon Nov 09, 2009 7:58 pm Post subject: Fuel Flow Problems, Again! (Vixen, Series-5) |
Guy sez:
| Quote: | Check out Highwing LLC. They also have a sensor and have a better
quality reputation than Murle.
I'm curious about this comment, Guy. Are you aware of quality issues
with Murle's parts?
Mike G.
N728KF, Kitfox IV-1200 Speedster
Phoenix, AZ
Lynn Matteson
Posted: Tue Nov 10, 2009 2:55 am Post subject: Fuel Flow Problems, Again! (Vixen, Series-5) |
I'll add my two cents worth here, if you don't mind, Mike.
I spoke with Murle on the phone regarding purchasing a low-fuel
warning system, but I already had the switch, so he sold me just the
receptacle/can, which was very nice of him. Only problem was, when I
got the can, the holes were tapped too large and the fittings screwed
in too far, making sealing them a bit of a problem. After I got that
problem solved, and painted it, I found that one of the end plate
welds was porous, and also leaked. I sent it back, requesting a new
can, but without any holes drilled into it. Murle was very
accommodating, and I'm happy with the overall outcome.
Lynn Matteson
Jabiru 2200, #2062, 812.1 hrs
Countdown to 1000 hrs~188 to go
Sensenich 62"x46" Wood prop
Rotec TBI-40 injection
Status: flying (and learning)
On Nov 9, 2009, at 10:56 PM, Michael Gibbs wrote:
<MichaelGibbs(at)cox.net>
Guy sez:
issues with Murle's parts?
Mike G.
Phoenix, AZ
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
