		mark.shimei(at)gmail.com Guest
				 Posted: Mon Nov 16, 2009 5:21 am    Post subject: Center wing gap opening |
				Well,this probably  isnt Kolb related ,since it is an Ultrastar,but I will put this out  anyway.
  My ULTRASTAR has  flown without the filler between between the center section for 60hrs+ since  April.  I have not noticed any loss of control at stalls or in any other  flight position,including landing....plenty of room to  flare.
  I installed a  velcroed gap filler with an alum. flashing leading edge to give it  stiffness,instead of using a center rib of sorts.
  The takeoff-climbout   seemed a little faster,but what really seemed to change was the pitching  up of the nose at cruise
  Originally I  needed to install a bungee to hold the stick back(John H trim) which worked  great. I now have to push FWD at level cruise(75%).  Just trying to  figure out why it changed so much
  On the flip side,I  can putter at 3200 rpm and sink about 80fpm or so.Havent dead-sticked it yet,but  will try it as soon as the weather changes.Got 10+ in so far,so I have a good  reference point.
  Mark
  |  | - The Matronics Kolb-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		Richard Pike
				 Posted: Mon Nov 16, 2009 8:26 am    Post subject: Re: Center wing gap opening |
				[quote="mark.shimei(at)gmail.com"]Well,this probably  isnt Kolb related ,since it is an Ultrastar,but I will put this out  anyway.
  Mark
 Dude - last I heard, Ultrastars are Kolbs - no problem.
 Shooting from the hip here, perhaps having the prop below the trailing edge of the wing keeps the airflow from exiting the gap to the extent it would if the prop is higher, thereby reducing the normal loss of lift. And the stick bungee worked the way you would expect.
 Now that you have a gap seal, the loss of air through the front part of the gap (where the prop draw would not have as much effect) is reduced, giving you a bit more lift at the forward part of the wing, changing your apparent center of lift forward. Now you have to hold forward stick to compensate. In any event, your center of lift has moved forward.
 Not sure if this is right, but that is how I am visualizing it. And as Beauford says, Worth what ya paid fer it.
 Richard Pike
 MKIII N420P (420ldPoops)
				 Posted: Mon Nov 16, 2009 10:44 am    Post subject: Center wing gap opening |
				At 08:26 AM 11/16/09 -0800, you wrote:
  	  | Quote: | 	 		   Originally I  needed to
 it changed so much
 Mark,
 Just to add a little to what Richard wrote.  By closing the wing gap, you
 have increased the effective length of your wing.  For the same thrust or
 throttle setting, the wing will generate more lift.   To maintain level
 flight, you must hold forward stick and reduce the AOA until the wing
 generates the same total lift as it did with out the gap seal.  If you are
 holding an uncomfortable amount of forward stick, you may need to adjust the
 horizontal stabilizer AOA.
 Jack B. Hart FF004
 Winchester, IN
		Dana
				 Posted: Mon Nov 16, 2009 4:45 pm    Post subject: Center wing gap opening |
				Whaddya talking about?  An UltraStar is certainly a Kolb!
  I posted on this a few weeks back after flying without the gap seal for the first (and last!) time.  Bottom line is that the plane handled very mushy, needed a lot more back stick to lift off, and the rate of climb was drastically reduced.
  -Dana
  At 08:20 AM 11/16/2009, mark.shimei wrote:
   	  | Quote: | 	 		  Well,this probably isnt Kolb related ,since it is an Ultrastar,but I will put this out anyway.
  Mark
   Back Up My Hard Drive? I Can't Find The Reverse Switch!    [quote][b]
