		msm(at)byterocky.net Guest
				 Posted: Sat Dec 31, 2005 6:10 pm    Post subject: Fuel tanks |
 Hi Guys, for your interest I have stripped the wings and noticed both fuel tanks have very small crazing in the glass which has been obviously leaking very slowly over the life of the plane. The defects appear to be from the tank mould when the glass was laid up. It is extremely thin in the areas that it has crazed and full depth penetrations appear to have occurred in at least 2 places. Fuel staining around both areas are obviously from long term leaking. The amount lost would appear to be very small and certainly not noticeable externally when undertaking a pre-flight inspection although a faint fuel smell has always been noticeable but down to the breather venting. Just thought I'd bring it to your attention!!.
 Cheers
 Graeme Toft
  |  | - The Matronics Kitfox-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		ddsyverson(at)comcast.net Guest
				 Posted: Sun Jan 01, 2006 6:41 am    Post subject: Fuel tanks |
 Graeme,
 Can you provide some additional information - I am curious if this is the
 nature of fiberglass, or, if this was entirely due to the particular tanks
 when they were manufactured (which it sounds like it might be).
 1) Any idea how old the tanks are?
 2) What kind of fuel was run in the tanks over their lifetime (100LL, Auto
 Gas, Corn gas - meaning real gas mixed with ethanol, etc)?
 3) Were the tanks coated with a sloshing compound, epoxy paint or anything
 else on the inside?
 4) What part of the tanks were the thin areas located?
 I just picked up a set of tanks (Not from Skystar) for the construction of my
 model 7 and they appear to be very well done - the fiberglass is thick and
 uniform and very rigid (triple baffled). The seams are very solid - not much
 evidence of bubbles in the resin anywhere.
 Any additional info on your observations would be useful and appreciated.
 Dave S
 St Paul, MN
 Graeme Toft
		aldaniels(at)fmtc.com Guest
				 Posted: Sun Jan 01, 2006 8:19 am    Post subject: Fuel tanks |
 I am sure, but John can help with this, if I remember correctly there
 was a change in resin and maybe manufacture of the Kitfox fuel tanks in
 about 1995 or so. The early tanks needed sloshed to keep fuel in and to
 keep from breaking down, the later takes were of a fuel resistant resin
 and better built.
 D& D Syverson wrote:
 Graeme,
		rliebmann(at)comcast.net Guest
				 Posted: Sun Jan 01, 2006 10:48 am    Post subject: Fuel tanks |
 I am wondering when and if my 13 gal fiberglass tank will give way after
 reading so much over time about the glass being susceptible to breakdown
 from various fuels. My tank came to me in 1990 from Denney Aircraft with no
 sloshing at all. The installation instructions said nothing about sloshing
 them. You could then and now see the glass weave in the tank. I have had no
 leaks at all. I guess I'll just keep watching for them.
 Ron N55KF
  	  | Quote: | 	 		   I am sure, but John can help with this, if I remember correctly there
 and better built.
 >Graeme,
		lcfitt(at)sbcglobal.net Guest
				 Posted: Sun Jan 01, 2006 11:43 am    Post subject: Fuel tanks |
 Ron, I think that is a good plan. Mine started leaking at abut 500 hours
 and was apparent by the blisters in the paint on the tops of the wings. Of
 course there was the slight fuel smell, that was always attributed to the
 various fuel line connections.
 Lowell
				 Posted: Sun Jan 01, 2006 12:31 pm    Post subject: Fuel tanks |
 Dave, the Kit was purchased in 1998 and fuel used has always been Avgas. No
 sloshing compound is obvious and I would say from there weight none has
 been applied in this case. It is only the bottom of the tanks that appear to
 be affected. The colour of the tanks are a bluish green. A friend in the
 fibre glass boating industry has inspected the tanks and is convinced the
 defects resulted from poor mould lay up of the glass. I would say one with
 defects such as this would be bad luck but to have 2 of them may be a
 concern for a few of us.
 Cheers
 Graeme Toft
		jdmcbean(at)cableone.net Guest
				 Posted: Sun Jan 01, 2006 12:36 pm    Post subject: Fuel tanks |
 June 1995 is when the change was introduced. Prior to that the tanks should
 be sloshed..
 Have a Safe New Year !!
 John & Debra McBean
 www.sportplanellc.com
 "The Sky is not the Limit... It's a Playground"
 Ron,
 Keep an eye on them.. some reported not having any issues...
 John McBean
		N93HJ(at)numail.org Guest
				 Posted: Sun Jan 01, 2006 5:10 pm    Post subject: Fuel tanks |
 John,
 Both of my tanks had a green and white sticker that said:
 QA Approved
 By: BC
 6-1-95
 Would you know which one I have?
 Thanks, Brett
				 Posted: Sun Jan 01, 2006 5:38 pm    Post subject: Fuel tanks |
 Brett,
 No way to know... the change actually took place prior to June... but there
 was no way to pin point the actual date prior to June...
 John & Debra McBean
				 Posted: Sun Jan 01, 2006 6:07 pm    Post subject: Fuel tanks |
 That's what I figured.
 Thanks anyway.
 I coated them just to be safe.
