what is 6B13-2??
chris Sinfield
PostPosted: Wed Nov 18, 2009 8:21 pm    Post subject: what is 6B13-2?? Reply with quote
having a look at the DRAFT upgrades on page 2 top RH corner ,Center spar + wing it lists a part called 6B13-2.. Now my plans don't have a -2 only 6B13-1
I thought I had all the updates .. does this part exist on page 6B13???
Chris
jaybannist(at)cs.com
PostPosted: Thu Nov 19, 2009 5:25 am    Post subject: what is 6B13-2?? Reply with quote
Chris,
I'm guessing that one of the uprights, bent to 85 deg, is 6B13-1; and the other one, bent to 95 deg. is 6B13-2. If I am correct, both these parts do show up on 6B13, but true to Zenith form, the part number is not called out on the detail drawing of the part. (That needs to change)
It is the forward one, bent to 85 deg. that is to be replaced with an extruded angle. That extruded angle, of course, is a 90 deg. angle.� I'm not sure how that is going to work.
Jay Bannister
--> Zenith601-List message posted by: "chris Sinfield" <chris_sinfield(at)yahoo.com.au (chris_sinfield(at)yahoo.com.au)>
Chris
http://forums.matronics.com/viewtopic.php?p=273672#273672
"_blank">www.aeroelectric.com
m" target="_blank">www.buildersbooks.com
"_blank">http://www.matronics.com/contribution
t" target="_blank">http://www.matronics.com/Navigator?Zenith601-List
sabrina
PostPosted: Thu Nov 19, 2009 7:11 am    Post subject: Re: what is 6B13-2?? Reply with quote
naumuk(at)windstream.net
PostPosted: Thu Nov 19, 2009 8:30 am    Post subject: what is 6B13-2?? Reply with quote
Jay-
If I'm following your description properly, the Sonex also uses the 85 degree L. There's a Homebuilder's Hint video on this subject on the EAA site. Check it out. I may be wrong, but it won't cost you anything to investigate.
Bill
chuck960
PostPosted: Thu Nov 19, 2009 8:24 pm    Post subject: Re: what is 6B13-2?? Reply with quote
The spar cap is 90 deg. (No change) The 85 deg angle on the upright should be ok. 95 deg. would be a problem.
Chuck
