ward.t(at)xtra.co.nz Guest
				 Posted: Thu Apr 13, 2006 6:21 pm    Post subject: Skin deformation around fuel inlet |
				Hi all,
 Has anyone had fuselage skin deforming below the fuel cap and in line with the fuel 'cobra' inside plastic fuel inlet.
 I heard it was to do with temperature differences and dark cover over this area with strong sunlight. Anyway I have it and would be interested in others who have and their remedy for it. My 'cobra' inlet does follow the line of the inside fuselage skin most of the way. Neville has given me good ways of fixing it below however would be interested if anyone else experienced it.
 Hi Tim,
 Only ever seen this if a dark cover is left on the fuselage in strong sunlight, if you can cut through the Bid straps that hold the ''cobra'' to the inside of the fuselage, and make up a polythene and ''gaffer tape'' tank on the outside, you can pour nearly boiling water into the ''tank'', and spring the fuselage back out, with gentle force from the inside. Balsa works well for that. After you have got the shape back, flox the balsa between the inner skin and the cobra, and get a couple of plies of Bid over the balsa, then put new straps over the lot.
 If all else fails it will be a case of filling and painting over the top.
 Nev.
 I heard the other day, estimates to have a coffin made for Gene Pitney, were 3 weeks from Oak,  but only 24 hours from Balsa.
  |  | - The Matronics Europa-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
