rayw
  Joined: 18 Jul 2009 Posts: 25 Location: Wisconsin, Central
				 Posted: Wed Nov 18, 2009 3:09 pm    Post subject: 503 Problems |
				Hello,
 I could use some help because I am running out of idea's. I have a 503 with dual Bing 54 carb's. The engine starts and runs well up to about 2000 RPM. After this RPM it has nothing left it just bogs. I have gone through both carbs so many times I could do it in my sleep. I don't think it is  fuel pump problem because I have rebuilt it and I have used the primer bulb to try to compensate for a potentially bad pump but this has no effect. The other day I ran it up to a point just before it bogged and put three fingers in front of the inlet of the right carb and got it to bog. I put three fingers in front of the inlet on the left carb and got a 1000 RPM rise. The carb on the left is an older type so I bought a brand new carb. Would you believe it? Same exact reaction. I went through the timing but I will probably go through it again to double check. Any body got any idea's? I have done so much that I can't even remember it all.
 Ray W.
  |  | - The Matronics KR-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
  http://www.matronics.com/Navigator?KR-List |
