		n277dl
		gengrumpy(at)aol.com Guest
				 Posted: Sun Nov 22, 2009 12:56 pm    Post subject: Exterior Paint - Alodine first? |
				I recommend you either use alodine or an etcher called "Prekote".
 Prekote is much friendlier to work with.
 Self etching primer does not do the job....
 grumpy
 N184JM
 On Nov 22, 2009, at 2:48 PM, n277dl wrote:
  Group,
   I'm getting to the point of painting.  I'm working with a local guy
  that works with a aircraft maintenance / painting facility.  Things
  are slow at work (not many investing in paint jobs on jets or
  Kingair's    ) and he has a body shop at his house that we'll use
  and I plan to paint before first flight.
  Question is around alodine.  On the 7A, I didn't alodine at all but
  used a self etching primer and sprayed over the top with Imron
  paint.  I've had no problems with the 7A but this time I'm working
  with a different individual and he is suggesting etch/alodine before
  paint.  I have no bias either way and would tend to allow the
  "expert" to choose his method.
  I'm curious if most "professional" shops etch/alodine or simply self
  etch prime the exterior in prep for paint?
  Thanks for any information on your experiences.
  Doug
  Doug
  "Fools" are always more creative than process people and
  will always find ways to ruin a perfectly good set of processes.
  http://forums.matronics.com/viewtopic.php?p 74326#274326
				 Posted: Sun Nov 22, 2009 2:34 pm    Post subject: Exterior Paint - Alodine first? |
				I had poor prep results with Prekote, I used SW aluminum etch with a red scotchbrite pad to prep the metal....Prekote requires much more physical labor to work...I know the USAF uses it but they also have  endless supplies if energetic Airmen to scrub the air frame with it
 Rick Sked
 N246RS
 Sent via BlackBerry by AT&T
				 Posted: Sun Nov 22, 2009 2:42 pm    Post subject: Exterior Paint - Alodine first? |
				Etch and Alodine is the accepted aircraft method....auto body shops use automotive methods except Land Rover...why? Aluminum body..Jet glow-made by SW recommends Alodine under their epoxy primer...so if your painter wants it I'd go with his recommendation....where is he gonna dump it in his garage after he applies it?
 Rick Sked
 N246RS
