CHT update
recapen(at)earthlink.net
PostPosted: Mon Nov 23, 2009 3:23 pm    Post subject: CHT update Reply with quote
As many of you may know, I have been obsessing a bit about my CHT's...to get them consistent.
Here's the setup:
IO360B1F6
9.2:1 pistons
AFP Fuel Injection
LASAR Ignition with CHT sender relocated to allow for testing
Vetterman Dual Crossover Heater/Mufflers
SamJames cowl and plenum
Advanced Flight Systems 3400 Engine Monitor
Oil Cooler mounted behind #4 cylinder
Air for both Heater/Mufflers behind #3 cylinder
For constant power setting, here's the consistency that I have achieved:
#1 and #3 cylinders run within three degrees (avg) of each other
#2 and #4 cylinders run within three degrees (avg) of each other
The #1/#3 cylinders run 8.5 degrees hotter (avg) than the #2/#4 cylinders
With the members of the sets of cylinders running this close each other, I'm thinking that I have the balance (front to rear) for each side pretty well matched.
I'm trying to wrap my head around what could be causing the right side to run hotter than the left. Here's some of what I'm thinking...: With this plenum set-up, I'm thinking that the pressure/volume should equalize from left to right. This would leave me with not much to change to cause more cooling air to go from the left to the right - meaning that I probably have to live with the differences. Alternatively, maybe it's not really hotter...the two sets of CHT wires for the left side (both equal length) are about three feet longer than the ones for the right side (again, both equal length). Could the difference in the lengths of the wires account for the reported temperature difference?
I'm pretty close to thinking that this is as good as it gets...but I would really like to know why...
Ralph
dsleepy47
PostPosted: Mon Nov 23, 2009 6:07 pm    Post subject: CHT update Reply with quote
The accuracy of the readings is a different question but the relative flow on each side should be controlled by the length of the baffle below and between the cylinders. increase the length of the baffle for the cold cylinders or or shorten the ones for the hot cylinders to change the balance. Remove the same amount from both ends of baffle if you don't want to change the balance between 1/3 or 2/4. I wouldn't have a pm with calling what you have close enough.
Deems
Here's the setup:
IO360B1F6
9.2:1 pistons
AFP Fuel Injection
For constant power setting C here's the consistency that I have achieved:
With the members of the sets of cylinders running this close each other C I'm thinking that I have the balance (front to rear) for each side pretty well matched.
I'm trying to wrap my head around what could be causing the right side to run hotter than the left.  Here's some of what I'm thinking...: With this plenum set-up C I'm thinking that the pressure/volume should equalize from left to right.  This would leave me with not much to change to cause more cooling air to go from the left to the right - meaning that I probably have to live with the differences.  Alternatively C maybe it's not really hotter...the two sets of CHT wires for the left side (both equal length) are about three feet longer than the ones for the right side (again C both equal length).  Could the difference in the lengths of the wires account for the reported temperature difference?
Thanks C
Ralph
lectric.com
/">www.buildersbooks.com
ebuilthelp.com
ww.matronics.com/contribution
nes-List">http://www.matronics.com/Navigator?LycomingEngines-List
ronics.com
Windows 7: It works the way you want. Learn more. [quote][b]
dsleepy47
N1491R
PostPosted: Tue Nov 24, 2009 5:19 am    Post subject: CHT update Reply with quote
Thanks Deems,
I haven't touched the underside baffling from Vans stock configuration. Good methodology suggestion! Based on a number of responses - I think I'll probably leave it alone for a while and see how it runs.
Ralph
dsleepy47
PostPosted: Tue Nov 24, 2009 9:35 am    Post subject: CHT update Reply with quote
That sounds like a reasonable plan to me. My guess without looking up the numbers is that your temperature differentials are with the margin of error for the instrument. If all the temperatures are below your limits I see no reason to change anything. I was just answering your question about how to affect individual cylinder temps not making a recommendation that it was necessary.
Deems
[quote] Date: Tue C 24 Nov 2009 08:17:05 -0500
To: lycomingengines-list(at)matronics.com
Subject: RE: CHT update
--> LycomingEngines-List message posted by: "Ralph E. Capen" <recapen(at)earthlink.net>
Thanks Deems C
Bing brings you maps C menus C and reviews organized in one place. Try it now.
dsleepy47
N1491R
PostPosted: Tue Nov 24, 2009 9:52 am    Post subject: CHT update Reply with quote
Deems,
All temps are within limits.
Glad to know there's something else I can do.....if it ever becomes necessary.
Flying on.....
Ralph
thomas(at)koelzer.us
PostPosted: Wed Nov 25, 2009 6:02 pm    Post subject: CHT update Reply with quote
Are you absolutely convinced the right side is running hotter than the left? Is there instrumentation error and can you confirm accuracy via another method or by swapping sensors? Do you have EGT numbers to confirm the cylinders are at the proper mixture but the cooling is inadequate?
Just some food for thought.
Tom
Here's the setup:
IO360B1F6
9.2:1 pistons
AFP Fuel Injection
Ralph
PostPosted: Wed Nov 25, 2009 6:16 pm    Post subject: CHT update Reply with quote
Tom,
Thanks for your input...
I have calibrated the sensors with boiling water and candy thermometer - and
swapped the sensors enough to know that the sensors are consistent and
accurate.
The EGT numbers show a good mixture distribution - but I haven't balanced
the injectors yet. That may change things when the balancing act is
accomplished - we'll see.
Some of the other postings provided info on a couple of other places to look
in the cooling system - just in case.
Most of the other postings told me to go have a coke and a smile - and
fly-on.
I'm planning to fly for a while - balance my injectors and see what happens.
Ralph
PostPosted: Wed Nov 25, 2009 7:17 pm    Post subject: CHT update Reply with quote
Sounds like you have it covered. Cokes and smiles are fine but I always enjoy the challenge of unanswered questions. It's what makes man so great and why we have achieved such heights.
Tom
On Nov 25, 2009, at 8:17 PM, Ralph E. Capen wrote:
Tom,
I have calibrated the sensors with boiling water and candy thermometer - and swapped the sensors enough to know that the sensors are consistent and accurate.
The EGT numbers show a good mixture distribution - but I haven't balanced the injectors yet. That may change things when the balancing act is accomplished - we'll see.
Some of the other postings provided info on a couple of other places to look in the cooling system - just in case.
Most of the other postings told me to go have a coke and a smile - and fly-on.
Ralph
