		cjhukill(at)cox.net Guest
				 Posted: Sun Nov 22, 2009 3:50 pm    Post subject: control stick wiring |
				I have received my Infinity grips and am trying to  determine how to run the big thick blue cable thru the stick, and out the  bottom. Seems to me, there would have to be considerable material removed to  route the cable thru the top of the stick where the vertical piece is welded to  the curved piece. This is a structural consideration. Another consideration is  the bottom of the tube, where there is all kinds of monkey motion to impede upon  by that cable. I'm thinking that clamping the cable to the aft side of the stick  and away from the bottom prior to the monkey motion, would be must prudent,  however, it would not look as cool. Has anyone come up with a good idea for  this?
  Chris Hukill
		Dick Sipp
				 Posted: Sun Nov 22, 2009 5:14 pm    Post subject: control stick wiring |
				Flight line interiors includes a leather like wrap to  cover the stick and an externally attached stick grip cable.  It has worked  fine for me and I think it looks good.
  Dick Sipp
  Sent: Sunday, November 22, 2009 6:47 PM
  Subject: control stick wiring
  Chris Hukill
		nukeflyboy
  Joined: 05 Jan 2008 Posts: 162 Location: Granbury, TX
				 Posted: Mon Nov 30, 2009 11:27 am    Post subject: Re: control stick wiring |
				Chris,
 I routed my cable thru the stick.  It took a little work but it can be done without a minimum bend radius issue.  I can send pics if you are interested.  To provide adequate clearance to the instrument panel the stick needs to be cut down too.  Also the grips should be clocked to avoid an uncomfortable wrist twist.
  _________________ Dave Moore
RV-6 built and sold
RV-10 built and flying |
