BEBERRY(at)aol.com Guest
Posted: Sat Apr 15, 2006 12:09 am Post subject: Navaid Autopilot (wing leveller) |
For some time I have been trying to get this item to work correctly. The
AP1 is o.k. and has been tested by the manufacturers. The servo seems not to
work correctly even when set up and calibrated acording to the manual.
Symptons.... Switch everything on , including Wing Leveller (all this on the
ground), and the servo actuating arm duly sets itself to a neutral position, taking
the control column with it, of course. Moving the turn knob on the AP then
has no effect. The servo actuating arm remains in the neutral position,
chattering away quietly to itself, but induces no stick movement.
Can anyone with a similar bit of kit help with any suggestions of where to
look next please?
Patrick
