jeff(at)rmmm.net Guest
Posted: Fri Apr 14, 2006 7:48 pm Post subject: Pitch Forces |
Hi All,
As a low time pilot that is enjoying his finished toy, I have noticed
the pitch forces are quite a bit greater than that of the aileron.
Thats while sitting on the ground or in the air at maneuvering speeds.
Reading other plane reviews over the years authors have noted this to
not be good or desirable.
I on the other hand haven't found it annoying but am wondering if other
Europas are like this. None of the push rods seem to be rubbing
anywhere. Is their any lubricant others have used and if so where has
it had the best effect? Any Ideas or advice would be appreciated.
Thanks In advance,
Jeff R.
A258 / Gold Rush... Flying off the 40
Posted: Fri Apr 14, 2006 11:46 pm Post subject: Pitch Forces |
Hi! Jeff.
Have you the trim system set to neutral and mid range? The little trim
tabs have the capability of deploying huge forces since the stabilators
are "all flying control" Until you have the feel of the pitch trim
sensitivity you will think the pitch is heavy. Since the pitch trim
motor is quite speedy you only require small "dabs" of power to it to
get a balanced trim control load.
Some can't hack the fast trim and have introduced a slower circuit
facility from the Allen Co. to either replace the Europa supplied relay
deck or similar.
I had a defective relay deck but for a long while they were saying it
was a a connection problem but then discovered it was the type of points
they used in the relay getting dirty. They sent me a replacement relay
and Bingo, problem gone. However to illustrate my point, if this
phenomenon occurred in flight the only way I could clear it was to allow
the trim to go all the way to the end limiter, initially I tried to hold
the controls against the forces but was so concerned about the loads I
then allowed the aircraft to do as the trim tabs were demanding until it
reversed back from the limiter to normal flight, making sure I stopped
it at the right place instead of needing to back off again! Of course
the forces are still present in the stabilators and trim tabs when this
happens but not right back to the control column. All quite scary really
but sorted out now.
It would be a major challenge to land the aircraft with the trim system
on maximum position either way.
Bob Harrison G-PTAG Europa MKI/Jabiru 3300
ami(at)mcfadyean.freeserv Guest
Posted: Sat Apr 15, 2006 12:51 pm Post subject: Pitch Forces |
It's normal/desirable to have the stick pitch forces higher than the roll
forces in a normal 'plane.
Albeit that the Kitfox had lighter pitch than roll, which contributed to its
interesting handling!
Duncan McF.
topglock(at)cox.net Guest
Posted: Sat Apr 15, 2006 6:01 pm Post subject: Pitch Forces |
Jeff,
I think the heavier pitch forces are normal. I've noticed the same
thing in Baby Blue. Never a problem, though, as the Europa responds
quickly to "ANY" movement of the stick.
On a side note, are you going to be up for the meeting with John at
Mattlews in mid May?
Jeff - Baby Blue N55XS
164 hours
JEFF ROBERTS wrote:
Hi All,
Thanks In advance,
Jeff R.
Posted: Sun Apr 16, 2006 5:21 am Post subject: Pitch Forces |
Hi Jeff,
Not sure if I'll have the 40 off. I'm having a serious time problem
right now. We have started building on the property I showed you. As
most people that have this flying disease I have built the
hanger/apartment first. Working on it, the land, running my business in
it's busy time, and flying off the 40. I need a clone!
There is nothing that sounds better than getting away for a Europa
weekend. If I cant fly to it I may even drive.
Thanks Bob H. and Jeff for your responses and keep me posted on the
date in May at Mathews.
Happy Easter to All!
Jeff
A258 Flying off the 40
On Apr 15, 2006, at 8:51 PM, Rman wrote:
Jeff,
164 hours
JEFF ROBERTS wrote:
> Hi All,
> other
> Thanks In advance,
> Jeff R.
