Kelly McMullen
Posted: Mon Nov 30, 2009 6:12 am Post subject: Fly off time 25 hrs or 40hrs (aerosport1) |
Has anyone researched what props are approved for either the Comanche
260 or Aztec 250? It would seem that any prop approved or STCd for
those aircraft could get a certified combination for the -10.
On Mon, Nov 30, 2009 at 6:40 AM, Peter James <RVPilot(at)mchsi.com> wrote:
I spoke with my DAR about this very topic recently. His take on the
situation was this:
· Even though my engine was certified, and my prop is a Hartzell
designed for the plane, the combination of the two had never appeared on a
“certified” on a production airplane. The combination to the best of his
knowledge had only appeared on an RV-10, which is an EXPEIMENTAL airplane.
Therefore, the combination still had to be considered experimental. Based
on this, he said that I was going to get 40 hours, like it or not.
A&P/IA, EAA Tech Counselor
KCHD |
rene(at)felker.com Guest
Posted: Mon Nov 30, 2009 6:50 am Post subject: Fly off time 25 hrs or 40hrs (aerosport1) |
I have a C4B5........the DAR was able to make that connection and only gave
me 25 hours. I known have 108 hours and still testing.
Now I am working on my mod list for my second annual......lets see...
Second battery of Firewall (for CG purposes and some redundancy)
Move the fuel pump switch next to throttle
Send autopilot back for new screen (second year on that one)
The list is a lot shorter this year.....
Rene' Felker
RV-10 N423CF Flying
801-721-6080
dlm46007(at)cox.net Guest
Posted: Mon Nov 30, 2009 7:55 am Post subject: Fly off time 25 hrs or 40hrs (aerosport1) |
In April 2008 my DAR concluded that a certified IO540 and a certified
Hatrzell prop warranted a 25 hour test period; I believe this as done on the
basis of it being an approved engine prop combination as designated by the
manufacturer of the kit.
Posted: Mon Nov 30, 2009 8:25 am Post subject: Fly off time 25 hrs or 40hrs (aerosport1) |
Pete,
If your DAR is talking about 91.203(b)(3), it says you have to have a
magnetic direction indicator. Your AFS uses a (highly accurate)
magnetometer to display magnetic heading. Nothing says it has to be
non-electric, or that it has to be a wet compass.
Dave Saylor
AirCrafters LLC
140 Aviation Way
Watsonville, CA 95076
831-722-9141 Shop
831-750-0284 Cell
situation was this:
Make that 91.205...
Dave Saylor
AirCrafters LLC
140 Aviation Way
831-722-9141 Shop
831-750-0284 Cell
On Mon, Nov 30, 2009 at 7:56 AM, Dave Saylor <dave.saylor.aircrafters(at)gmail.com (dave.saylor.aircrafters(at)gmail.com)> wrote:
[quote] Pete,
If your DAR is talking about 91.203(b)(3), it says you have to have a magnetic direction indicator. Your AFS uses a (highly accurate) magnetometer to display magnetic heading. Nothing says it has to be non-electric, or that it has to be a wet compass.
Dave Saylor
AirCrafters LLC
140 Aviation Way
831-722-9141 Shop
831-750-0284 Cell
On Mon, Nov 30, 2009 at 5:40 AM, Peter James <RVPilot(at)mchsi.com (RVPilot(at)mchsi.com)> wrote:
I spoke with my DAR about this very topic recently. His take on the situation was this:
· Even though my engine was certified, and my prop is a Hartzell designed for the plane, the combination of the two had never appeared on a “certified” on a production airplane. The combination to the best of his knowledge had only appeared on an RV-10, which is an EXPEIMENTAL airplane. Therefore, the combination still had to be considered experimental. Based on this, he said that I was going to get 40 hours, like it or not.
· One interesting point that we discussed. He said the local FSDO here in Iowa was growing more lenient about the 25 mile radius for testing. He had discussed the flying speed of the RV-10 and said at the speeds we fly, it seemed that you were always ‘turning left’ to stay within the radius. Therefore, he had been given leniency to pick an airport 100 miles away and allow flight testing in a straight line to it. As example, I will likely base out of Ankeny, Ia(ILV) and will request a destination of Burlington, IA (BRL). In that line of flight, I will fly over Pella, Oskaloosa, Ottumwa, Fairfield, and Mt. Pleasant. There is always an airport nearby in case of emergency. Being that I have family in two of those cities, I will be able to stop for lunch during my flight testing time.
· One other area that I pressed him about was this: I wish to eliminate the ‘wet compass’ from my panel. I have dual AFS screens, with dual AHARS, both with battery back-up. My question was why do I have to have a wet compass? He said that there was no provision in the FARs to allow it to be eliminated. He said the rules were written in the 60’s or before, and they had not been updated for current technologies. He said I needed to write a letter to the FSDO or standards office in Oklahoma. Has anyone done this? I’d sure like to eliminate the compass cluttering up the windscreen.
p.s. As a side note, I have lost my job. I hope to get reemployed before I am required to sell the plane. If you know of anyone needing a sales and marketing pro, please let me know.
Pete
RV-10 Escalade - the never ending project.
Time: 05:55:40 PM PST US
Subject: Fly off time 25 hrs or 40hrs
From: "aerosport1" <g.combs(at)aerosportmodeling.com (g.combs(at)aerosportmodeling.com)>
I am looking for some feed back on the hours that people were required
to fly off if they had the stock 2 blade Hartzell prop and the DA45 experimental
engine from Aerosport Power or other know builder. Was it 25 or 40. And if 25
why instead of 40.
Just curious. I have heard both ways with this combo. Email me off the list
if you would like.
Thanks Geoff
Geoff Combs
RV-10 QB N829GW
Finishing
http://forums.matronics.com/viewtopic.php?p=275369#275369
_blank">www.aeroelectric.com
