RVPilot(at)mchsi.com Guest
Posted: Mon Nov 30, 2009 5:43 am Post subject: Fly off time 25 hrs or 40hrs (aerosport1) |
I spoke with my DAR about this very topic recently. His take on the situation was this:
<![if !supportLists]>· <![endif]>Even though my engine was certified, and my prop is a Hartzell designed for the plane, the combination of the two had never appeared on a “certified” on a production airplane. The combination to the best of his knowledge had only appeared on an RV-10, which is an EXPEIMENTAL airplane. Therefore, the combination still had to be considered experimental. Based on this, he said that I was going to get 40 hours, like it or not.
<![if !supportLists]>· <![endif]>One interesting point that we discussed. He said the local FSDO here in Iowa was growing more lenient about the 25 mile radius for testing. He had discussed the flying speed of the RV-10 and said at the speeds we fly, it seemed that you were always ‘turning left’ to stay within the radius. Therefore, he had been given leniency to pick an airport 100 miles away and allow flight testing in a straight line to it. As example, I will likely base out of Ankeny, Ia(ILV) and will request a destination of Burlington, IA (BRL). In that line of flight, I will fly over Pella, Oskaloosa, Ottumwa, Fairfield, and Mt. Pleasant. There is always an airport nearby in case of emergency. Being that I have family in two of those cities, I will be able to stop for lunch during my flight testing time.
<![if !supportLists]>· <![endif]>One other area that I pressed him about was this: I wish to eliminate the ‘wet compass’ from my panel. I have dual AFS screens, with dual AHARS, both with battery back-up. My question was why do I have to have a wet compass? He said that there was no provision in the FARs to allow it to be eliminated. He said the rules were written in the 60’s or before, and they had not been updated for current technologies. He said I needed to write a letter to the FSDO or standards office in Oklahoma. Has anyone done this? I’d sure like to eliminate the compass cluttering up the windscreen.
p.s. As a side note, I have lost my job. I hope to get reemployed before I am required to sell the plane. If you know of anyone needing a sales and marketing pro, please let me know.
Pete
RV-10 Escalade - the never ending project.
Time: 05:55:40 PM PST US
Subject: Fly off time 25 hrs or 40hrs
From: "aerosport1" <g.combs(at)aerosportmodeling.com>
I am looking for some feed back on the hours that people were required
to fly off if they had the stock 2 blade Hartzell prop and the DA45 experimental
engine from Aerosport Power or other know builder. Was it 25 or 40. And if 25
why instead of 40.
Just curious. I have heard both ways with this combo. Email me off the list
if you would like.
Thanks Geoff
Geoff Combs
RV-10 QB N829GW
Finishing
http://forums.matronics.com/viewtopic.php?p=275369#275369
Posted: Mon Nov 30, 2009 6:09 am Post subject: Fly off time 25 hrs or 40hrs (aerosport1) |
Peter James wrote:
situation was this:
SNIP
· One other area that I pressed him about was this: I wish to
Get a suction-cup mounted compass from Wall-world. Stick it anywhere
you can see it .... not necessarily read it ....
I read this and the first thought was "You picked a fine time to leave
me, my job". My condolences. I've got my fingers crossed. Thankfully
I'm retired and although I've lost a fair amount of money in real
estate, I'm still hanging in there. Best of luck.
Linn
Pete
experimental
if 25
why instead of 40.
if you would like.
Thanks Geoff
Geoff Combs
RV-10 QB N829GW
Finishing
http://forums.matronics.com/viewtopic.php?p 75369#275369
AV8ORJWC
Posted: Mon Nov 30, 2009 7:57 am Post subject: Fly off time 25 hrs or 40hrs (aerosport1) |
I would love to hear from any DAR that can grant a 25 hour experimental flyoff for a Subaru 'non TCDS' engine/prop combination. 40 seems to have a solid basis in safe flight. And, Scotts perspective has been well proven with the current fleet. Anyone remember Dan Lloyd's flyoff? Where's Das Fed when you need a sound voice?
Extended operational ranges from the Base of Operation (while avoiding congested areas) for Phase One makes a lot of sense.
The requirement for a redundant compass was not based on either the 60's or a resistance to what is now called "current technologies". Lightning strikes, EMF and a multitude of primitive failures of electrons force even 21st century glass cockpits pushed out of the factories of 2010 to retain an ISI and a compass. Anyone remember the French flight out of South America that went down over the Atlantic? It will be interesting to see the rewrite that changes the old - proven technology of the paper, tube and fabric era. Till you lose all electrical and the back-up fails you simply haven't discovered the road traveled from the stick and rudder days. Fly by wire and glass EFIS have some damned expensive triple redundant systems which are beyond even the budgets of RV-10 builders.
Oh Yeh, Happy Birthday MATT!
John Cox
-pushin electrons-
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Peter James
Sent: Monday, November 30, 2009 5:41 AM
Subject: re: Fly off time 25 hrs or 40hrs (aerosport1)
Pete
why instead of 40.
if you would like.
Thanks Geoff
Geoff Combs
RV-10 QB N829GW
Finishing
http://forums.matronics.com/viewtopic.php?p=275369#275369 [quote] [b][b]www.aeroelectric.comwww.homebuilthelp.com[b][b]http://www.matronics.com/contribution[b][b][b][/b][/b][/b][/b][b]http://www.matronics.com/Navigator?RV10-List[b][/b][b]http://forums.matronics.com[b] [b]
