Posted: Fri Apr 14, 2006 7:38 am Post subject: Oxygen Sensor on a Two Stroke Engine |
Kolbers,
Have you or do you know of anyone who has mounted an oxygen sensor on a two
stroke engine?
Jack B. Hart FF004
Winchester, IN
Richard Pike
Posted: Fri Apr 14, 2006 9:20 am Post subject: Oxygen Sensor on a Two Stroke Engine |
No, but if some of us get any older, we will be mounting one on the
microphone boom, just to monitor how we're doing...
Richard Pike
MKIII N420P (420ldPoops)
PLEASE do not archive
Jack B. Hart wrote:
Kolbers,
stroke engine?
Jack B. Hart FF004
Winchester, IN
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
herbgh
Posted: Fri Apr 14, 2006 9:58 am Post subject: Oxygen Sensor on a Two Stroke Engine |
Jack
Wonder how the O2 sensor would handle the oil mix? Herb
On Fri, 14 Apr 2006 13:18:21 -0400 Richard Pike <richard(at)bcchapel.org>
writes:
| Quote: | Jack B. Hart wrote:
<jbhart(at)onlyinternet.net>
> Kolbers,
on a two
> stroke engine?
> Jack B. Hart FF004
> Winchester, IN
Posted: Fri Apr 14, 2006 10:57 am Post subject: Oxygen Sensor on a Two Stroke Engine |
At 12:55 PM 4/14/06 -0500, you wrote:
Jack
Herb,
I am using Opti-2 which seems to be a non smoke oil. I have emailed them to
ask if their oil would kill an O2 sensor, but I have not recieved a reply.
The position for O2 sensor placement has already been predetermined. I
placed a second EGT probe down stream from the position recommended by
Simoninni. My thought was that if the plugs read rich and the EGT was
running at the upper limit maybe a probe down stream would read lower. It
did not. It consistently reads 100 degrees F hotter. So when I take off
the second EGT sensor, I will weld an O2 sensor adaptor to the pipe at this
location.
Jack B. Hart FF004
Winchester, IN
Russ Kinne
Posted: Fri Apr 14, 2006 1:26 pm Post subject: Oxygen Sensor on a Two Stroke Engine |
Dear middle-aged poops (you ain't old yet!)
Good idea about an O2 supply on the mike boom -- after years of
swordfish spotting, banner towing, whale surveys, parcel drops &
pickups -- I go on O2 at 1000'! -- how could I manage that in a
Kolb ? Maybe I'd never fly that high anyway --
Richard Pike
J
pj.ladd(at)btinternet.com Guest
Posted: Sat Apr 15, 2006 8:39 am Post subject: Oxygen Sensor on a Two Stroke Engine |
I go on O2 at 1000'! -- how could I manage that in a Kolb ? Maybe I'd
never fly that high anyway -->>
Hi Russ,
I assume you meant 10,000 ft..
Mick Moulai tells me today that he had my Xtra up to 10500ft and still
climbing yesterday as part of the test programme on my machine.
The programme is almost finished and I may actually get my hands on the
plane myself in the next couple of weeks.
Cheers
Pat
Russ Kinne
Posted: Sat Apr 15, 2006 1:04 pm Post subject: Oxygen Sensor on a Two Stroke Engine |
Pat
No, I meant 1,000 feet! -- the low level is where I work -- & shine.
And smile!
Glad to hear your bird got to 10,500! You'll have a ball when all the
folderol is over --
Fair winds,
Russ
On Apr 15, 2006, at 12:27 PM, pat ladd wrote:
I'd
Hi Russ,
the
Cheers
Pat
