logansc
Posted: Mon Dec 07, 2009 11:40 am Post subject: Switchology Question |
Guys: I have a newly finished Rocket, wired IAW Z13-8. My system has a big battery, a 60 amp alternator (Plane Power) and an SD-8 backup. I have not tested the SD-8 yet and was wondering if there is a protocol for that, that I should observe.
I have a three position main DC Master switch (off, Batt, on) and no avionics master (I prefer turning each on and off individually). I also have separate E-bus Alt Feed and Aux Alternator on-off switches. I plan to test my SD-8 on the ground with all my avionics off except my engine monitor (which has my volt and ammeters) to see if it is wired correctly and shows Aux Alternator output. Should I start on the main system, turn on the engine monitor, and then switch the main to Batt, and then the E-bus on, and then the Aux Alt on, and then the Batt off?
If that is all correct, then airborne if I lose or shut down the main alternator, is the sequence the same? Haven't got the diagrams with me at the moment and I'm trying to write a procedure. Any help would be appreciated.
Lee...
Posted: Mon Dec 07, 2009 6:44 pm Post subject: Switchology Question |
At 01:40 PM 12/7/2009, you wrote:
You can't hurt anything with by mis-positioning switches.
You won't see any output from the SD-8 without being
well above 2000 rpm. So you can craft any procedure that
makes sense to you.
(o o)
===========o00o=(_)=o00o=========
< Go ahead, make my day . . . >
< show me where I'm wrong. >
logansc
Posted: Tue Dec 08, 2009 4:48 am Post subject: Re: Switchology Question |
Bob: Thanks for the response. I'll work out a "switchology" sequence today and try it this afternoon.
Lee...
jpx(at)qenesis.com Guest
Posted: Tue Dec 08, 2009 11:02 am Post subject: Switchology Question |
| Quote: | You won't see any output from the SD-8 without being
This caught me off guard and triggered me to look at the specs on the
B&C website.
I often cruise at 2200rpm.
Their web site says that for a Lycoming engine, the vacuum pad runs
1.3:1 compared to the crankshaft.
So at 2200 rpm, the SD-8 is turning 2860 rpm.
Interpolating their chart idicates about 6A at that speed.
While idling, I will get a low voltage indication on my aux bus that I
hadn't anticipated. Perhaps I should be considering an SD-20.
Jeff Page
Dream Aircraft Tundra #10
