		Bob Turner
				 Posted: Mon Dec 07, 2009 7:52 pm    Post subject: electric fuel pump current |
				I've been following Van's electrical kit instructions: they call for a 5 Amp breaker for the fuel pump (the one sold by Van's). But today I noticed the pump instructions say it draws 5 amps; they call for a 7 or 10 amp breaker. Has anyone run this pump on a 5 amp breaker without false trips?
  _________________ Bob Turner
RV-10 QB |
		partner14
				 Posted: Mon Dec 07, 2009 9:06 pm    Post subject: electric fuel pump current |
				Your judgement is correct.... use at least a 7.5amp breaker.
  Don McDonald
40636 |
				 Posted: Tue Dec 08, 2009 4:32 am    Post subject: electric fuel pump current |
				As was already mentioned in a reply, it needs at least a 7.5A breaker.  If you use the right size wire, I would go with a 10A.  Van's wiring guide is designed for a carbureted engine, not a fuel injected one.  I don't understand why.  How many on the list are going carbureted?  I think this is one of the only places where it matters, but it does matter.  The boost pump for a carbureted engine only puts out less than 10 PSI, so it doesn't draw as much current.  I don't understand why they didn't just size the wire enough for a 10A breaker and put that in the kit.  A 10A breaker is fine for a low-pressure pump, but not vice versa for the 5A.
 Anyway, that's the reason it's in the kit.  I found out the hard way about 5 years ago.
 Jesse Saint
 Saint Aviation, Inc.
 jesse(at)saintaviation.com
 Cell: 352-427-0285
 Fax: 815-377-3694
 On Dec 7, 2009, at 10:52 PM, Bob Turner wrote:
  Bob Turner
  RV-10 QB
  http://forums.matronics.com/viewtopic.php?p 76665#276665
