klaus.dietrich(at)oracle. Guest
Posted: Wed Dec 09, 2009 2:25 am Post subject: MkI with 912S |
After over 1000h on my good 912, I'm thinking about "upgrading" my Europa "Mk I" (mono) with a new 912 "S" engine.
I'm wondering if the "Mk I" cowling with it's radiators will be ok for the 912S, or if I have to change the cowling/engine mount etc to the "Mk II" version...
In my current installation I have mounted the oil cooler just below the spinner in the lower cowling and never had any tempreature issues.
Is anybody out there having an original "Europa Mk I" with a 912S?
Appreciate your advise!
Klaus
(OE-CKD, 134)
pete(at)lawless.info Guest
Posted: Wed Dec 09, 2009 3:03 am Post subject: MkI with 912S |
Hi Klaus
I have been thinking of doing the same thing. The 912S is the same size as the 912 so no problem for a direct exchange. – However, Nigel Charles found that the larger starter motor available for the 912S would not fit with the Classic engine mount (so use smaller starter and the ‘soft start’ pack. Also I understand from Peter Rees that the new AC mechanical fuel pump will not fit as it fouls the radiator on the Classic. The original pump is available Peter sent me the following contact who can supply.
Pete
Pump came from a Pieburg distributor in Germany (he seems to send the pumps
and rely on trust for you to send the money!) - he can be contacted at
www.ruddies-burlin.de the pump model number is 7.20971.55
Posted: Wed Dec 09, 2009 5:28 am Post subject: MkI with 912S |
Klaus
There was a type in the contact address for the pump should be /www.ruddies-berlin.de/
Pete
