Kind of off topic. Speed sensor needed.
Goto page 1, 2  Next
Sam
PostPosted: Mon Dec 14, 2009 1:55 pm    Post subject: Kind of off topic. Speed sensor needed. Reply with quote
Aeroelectric listers,
We're looking for a bright idea.  Preferably an inexpensive one.
The Sport Air Racing League, http://www.sportairrace.org/ is trying to develop an accurate and reliable way to time the speed of  an aircraft zooming down a runway, at 50 feet or so.  They are looking for some kind of trigger that will start the clock at one end, and stop it at the far end.
We don't really want to erect pylons to fly through to break a beam, that would be unwieldy. Some of the guys have looked at airborne systems, such as GPS tracking, but it's not accurate enough.
The SARL group is having a hard time coming up with something.  Anybody have any thoughts how we might accomplish this?
Thanks for any ideas.
Sam Hoskins
Race 22!
Sam Hoskins
www.samhoskins.blogspot.com
skywagon
PostPosted: Mon Dec 14, 2009 2:48 pm    Post subject: Kind of off topic. Speed sensor needed. Reply with quote
Hi Sam,
One of the old fashion systems might be considered.
Mounting a gun sight device on a tripod and having some young person, with good tracking reflexes man it. Maybe a skeet and trap gunner. He sights on the aircraft nose and as it comes over the finish line, the swinging and tracking of the gun sight rides over a micro switch with a very fast make or break. This swt. action starts and/or stops a clock. If the operator has trouble tracking the nose of the aircraft, then all bets are off of course.
You are sure right about gps. All but, maybe some military designs do not update fast enough. You would probably need one that updates and calculates at a minimum of 1 millisec. or faster.
David
mrspudandcompany(at)veriz
PostPosted: Mon Dec 14, 2009 3:25 pm    Post subject: Kind of off topic. Speed sensor needed. Reply with quote
Sam Hoskins
Race 22! [quote] Sam, Have you considered a hand held radar gun, similar to the ones police departments use for traffic speed?? Roger[b]
Robert Reed
PostPosted: Mon Dec 14, 2009 3:36 pm    Post subject: Kind of off topic. Speed sensor needed. Reply with quote
You didn't indicate rather the speed sensor could be mounted in the plane or needed to be on the ground. If it could be mounted on the plane I would say that a low powered laser similar to those use in a grocery check out could be used with ground based reflectors. I can't see any problem with using the same system with a ground based unit since the lights are of brief duration and low power.  They are widely used by police and highway patrols. The accuracy would be great.
To: Aerolectric List <aeroelectric-list(at)matronics.com>
Sent: Mon, December 14, 2009 3:01:20 PM
Subject: Kind of off topic. Speed sensor needed.
Sam Hoskins
Race 22!
FLYDAD57(at)neo.rr.com
PostPosted: Mon Dec 14, 2009 4:19 pm    Post subject: Kind of off topic. Speed sensor needed. Reply with quote
Would a radar gun, like the cops use, work??
Sam
PostPosted: Mon Dec 14, 2009 6:05 pm    Post subject: Kind of off topic. Speed sensor needed. Reply with quote
Radar guns were used with the AirVenture Cup racers several years ago and I think they didn't work too well.  The SARL guys are looking for some precise timing.
They currently are using sighting rods and triangulation, but it is leaving too much judgment to the timing person.  I think that would also apply to David's suggestion.
They want to capture a full runway length of time, to have a more representative view of true speed, rather than just a snapshot that a radar gun might provide.
An aircraft mounted lasar system might to it, but how.where would you mount it to many different kinds of aircraft, and in such a way that it would not create drag?
These are the problems the SARL guys are trying to work around.
Thanks for the suggestions.
Sam
On Mon, Dec 14, 2009 at 6:16 PM, Robert D. Taylor <FLYDAD57(at)neo.rr.com (FLYDAD57(at)neo.rr.com)> wrote:
[quote] Would a radar gun, like the cops use, work??
Sam Hoskins
william_slaughter(at)att.
PostPosted: Mon Dec 14, 2009 6:45 pm    Post subject: Kind of off topic. Speed sensor needed. Reply with quote
Google “race car timing systems” and you will get lots of hits for transponder type systems. Don’t know how they would relate to your budget, but they are widely used, and not just at the professional level, so hopefully there would be one that would work for you.
Will Slaughter
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Sam Hoskins
Sent: Monday, December 14, 2009 3:01 PM
Sam Hoskins
Race 22!
www.aeroelectric.com
PostPosted: Mon Dec 14, 2009 6:48 pm    Post subject: Kind of off topic. Speed sensor needed. Reply with quote
Yes, photo cells looking straight up though a tube of 2 - 4"
and length adjusted so that subtended angle of view is sufficiently
small that the "shadow" of any part of the aircraft blocks the
skylight. There are some self-calibrating level sensor circuits
that will adjust for slow variability in sky light levels.
(o o)
===========o00o=(_)=o00o=========
< Go ahead, make my day . . . >
< show me where I'm wrong. >
PostPosted: Mon Dec 14, 2009 7:22 pm    Post subject: Kind of off topic. Speed sensor needed. Reply with quote
College cross country teams use transponders to track runners and their positions crossing the finish line. Maybe some adaptation of this equipment could be employed.
ainut(at)hiwaay.net
PostPosted: Mon Dec 14, 2009 8:25 pm    Post subject: Kind of off topic. Speed sensor needed. Reply with quote
etienne.phillips(at)gmail
PostPosted: Mon Dec 14, 2009 10:11 pm    Post subject: Kind of off topic. Speed sensor needed. Reply with quote
This would work well - even if the light sensor wasn't in a tube, calibrated correctly, the change from direct sunlight to shadow should be enough to trigger a timing device of some description. I would suggest two or three sensors in a line across the runway. Then use the second or third sensor that is triggered so that you know it's the wing that's causing the shadow both times, and not the wing on the first end, and the spinner on the second (which would skew results).
Even a very simple microprocessor would be able to do the timing accurately enough, and could display the result on an LCD screen without too much effort.
There is one downside to this, if you're keen on using either end of a runway, I guess you're looking for about 1km between sensors. That's a lot of wire to wind up at the end of each competition! There may be some simple radio interfaces that could be substituted...?
Etienne
Robert Reed
PostPosted: Tue Dec 15, 2009 7:03 am    Post subject: Kind of off topic. Speed sensor needed. Reply with quote
If the laser were ground mounted the only thing required on the plane might be a couple of identifiable stripes of paint on the underside of the aircraft. It would not require a high powered laser and shouldn't pose any danger to the pilot since the directionality of the beam would be vertical and not directed at the pilot.
If the laser were mounted inside the plane it wouldn't require more than a dime sized opening that could be covered with glass. The laser beam would be setup to oscillate back and forth with a ground based sensor to detect the beam as the plane crossed the detection points.  The size of current low power lasers are so small that there should be no problem with either weight or drag.
Bob
To: aeroelectric-list <aeroelectric-list(at)matronics.com>
Sent: Mon, December 14, 2009 8:01:49 PM
Subject: Re: AeroElectric-List: Kind of off topic. Speed sensor needed.
Sam
PostPosted: Tue Dec 15, 2009 7:56 am    Post subject: Kind of off topic. Speed sensor needed. Reply with quote
E: This would work well - even if the light sensor wasn't in a tube,
You need to constrain the view angle . . .preferably
without the use of optics. Long tubes seem the simplest
approach.
E: I would suggest two or three sensors in a line across the runway.
skew results).
That would be useful . . . depending on how "loose"
the rules are for alignment with the runway ceneterline,
an array of senors of any number could be used.
E: Even a very simple microprocessor would be able to do the timing
Sure, the jellybean PIC products offer one set of
solutions.
E: There is one downside to this, if you're keen on using either end
Ten years ago, I helped some RC racers craft a timing system
that required communication over a many acres of event
venue. Off the shelf, 433 MHz transmiter and receiver
modules provided links. Controlling atency and jitter in
detecting event-edges would be a critical design goal.
Assuming 300 mph (440 f/s) over 5000 feet of runway
(11.3 seconds) a .1% accuracy in timing would call for
control of variability to less than 10 milliseconds.
If shorter runs are anticipated, the number gets tighter.
+/-1 millisecond would probably be a practical design goal.
Sam. Define "accurate". What are the design goals for
the reduction of uncertainty?
david.nelson(at)pobox.com
PostPosted: Tue Dec 15, 2009 8:05 am    Post subject: Kind of off topic. Speed sensor needed. Reply with quote
Hi Sam,
Are you wanting something that displays/announces the avg speed in near real-time
(ie after the plane passes the end of the runway) or this something that is
announced at the end of show?
/\/elson
Sam Hoskins
Race 22!
PostPosted: Tue Dec 15, 2009 8:31 am    Post subject: Re: Kind of off topic. Speed sensor needed. Reply with quote
Sam,
How about using two clocks and two cameras? Synchronize two very accurate clocks or stop watches and locate them at opposite ends of the runway. Take fast pictures of the plane (including the clock) as it passes starting and ending points. Review the pictures and note the times on the clocks and subtract.
Joe
Joe Gores
raymondj(at)frontiernet.n
PostPosted: Tue Dec 15, 2009 10:57 am    Post subject: Kind of off topic. Speed sensor needed. Reply with quote
The NASA system could be turned upside down with the sweeping laser
fixed and the retroreflective tape on the underside of the aircraft.
Someone suggested the laser from a grocery store scanner as a painting
laser. The retroreflective tape is available from SAR equipment suppliers.
NASA system link:
http://searchandrescue.gsfc.nasa.gov/techdevelopment/l_sar.html
Just my thoughts.
Raymond Julian
Kettle River, MN
Robert Reed wrote:
[quote] If the laser were ground mounted the only thing required on the plane
Bob
*To:* aeroelectric-list <aeroelectric-list(at)matronics.com>
*Sent:* Mon, December 14, 2009 8:01:49 PM
*Subject:* Re: Kind of off topic. Speed sensor needed.
Sam
peter(at)sportingaero.com
PostPosted: Wed Dec 16, 2009 10:15 am    Post subject: Kind of off topic. Speed sensor needed. Reply with quote
That reminds me! I saw this system used in a rowing race (over several
miles), 2 cameras at the start, and 2 at the finish (in case of failure
- 400 boats competing), all cameras filmed a 'master clock' to
synchronise their own clocks before the start. Does require some effort
after the speed runs, but only cost is 2 digital camcorders.
Peter
user9253 wrote:
Sam,
Joe
Joe Gores
http://forums.matronics.com/viewtopic.php?p 77622#277622
Sam
PostPosted: Thu Dec 17, 2009 5:50 am    Post subject: Kind of off topic. Speed sensor needed. Reply with quote
Bob, I think that 1 millisecond accuracy would be fine.  I think, just my opinion, if we could determine speed to one digit, it would be fine, eg. 234.6 mph.  Of course, two digits would be better.
Thanks to all who contributed suggestions.  I have complied and posted all of them to the SARL racers group.
For anyone who may be interested and wish to join, the e-mail list is at: http://groups.yahoo.com/group/SARL-Racers/
Sam
On Tue, Dec 15, 2009 at 9:54 AM, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
[quote]--> AeroElectric-List message posted by: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)>
E: This would work well - even if the light sensor wasn't in a tube, calibrated correctly, the change from direct sunlight to shadow should be enough to trigger a timing device of some description.
  approach.
E: I would suggest two or three sensors in a line across the runway. Then use the second or third sensor that is triggered so that you know it's the wing that's causing the shadow both times, and not the wing on the first end, and the spinner on the second (which would skew results).
E: Even a very simple microprocessor would be able to do the timing accurately enough, and could display the result on an LCD screen without too much effort.
  solutions.
E: There is one downside to this, if you're keen on using either end of a runway, I guess you're looking for about 1km between sensors. That's a lot of wire to wind up at the end of each competition! There may be some simple radio interfaces that could be substituted...?
="_blank">www.aeroelectric.com
ooks.com" target="_blank">www.buildersbooks.com
et="_blank">www.homebuilthelp.com
le, List Admin.
Sam Hoskins
PostPosted: Thu Dec 17, 2009 7:09 am    Post subject: Kind of off topic. Speed sensor needed. Reply with quote
It's technically feasible to get about any resolution
you want but the costs of producing a user-friendly
system can go up really fast as you add those decimal
points!
I did a drag track clocking system design many many
moons ago wherein we used telescopes looking across
the track at a strong light source. Magnification was
so high that the entire illumination disk (6" roundel)
filled the field of view in the telescope eyepiece.
This system was vacuum tube sensor systems driving
an HP counter/timer that was also vacuum tube and
used columns of neon bulbs to display measured
result.
In this instance, ambient light had no measurable
effect on triggering accuracy. It worked equally
well at night or bright sunlight. Further, uncertainty
of trigger timing was limited to the time it took
for the vehicle to cross the 6" field of view. So
back in 1974 or thereabouts, we had 0.1 mS resolution
and 1 mS accuracy of timing over the distance between
sensors. I think they installed them 10' apart at the
end of the track. At 150 f/s, the interval of interest
was about 66 milliseconds so we could calculate speed
with an accuracy of about 1.5% Folks were impressed
by that kind of capability back then.
Photo-detectors looking at sky-light through tubes
(or even cheap telescopes) offers a means by which
uncertainty in trigger timing (dd/dt) can be very small.
But as others pointed out, very small apertures,
require resolution of the differences between a prop
spinner and leading edge of wing. So an array of
sensors driving a discriminator calling for two
or more sensors to be triggered before the hack
is marked seems to offer a solution.
The use of radio to tie the ends of the system together
is quite practical. There are inexpensive, off the shelf
timers available with micro-second resolution/accuracy.
The proof of the pudding is in the sensor array.
( -Thomas Paine 1776- )
PostPosted: Thu Dec 17, 2009 8:44 am    Post subject: Kind of off topic. Speed sensor needed. Reply with quote
What is the size of the "box" that the aircraft must stay inside
and what height above the ground is the lower edge of that box?
I occurs to me that if you have a 100' wide by 100' high
box with lower edge at 100' agl, the number of sensors
required to cover that up-look area with any resolution
could be pretty big. Fortunately, they're cheap and easy
to build. So is the electronics for resolving the presence
of an airplane "shadow"
(o o)
Goto page 1, 2  Next
Page 1 of 2
