kelmonroe(at)COMCAST.NET Guest
Posted: Sun Dec 06, 2009 2:28 pm Post subject: Parts needed |
I have a CJ I need some parts for.
1.The radio receiver (WL5) tray that is attached to the receiver that slides in on the right rear side panel.
2.The nose wheel retract cylinder boot.
3.The loop antenna plastic panel H2-0132-00.
4.Gaskets/seals for the center consumtion tank.
5.Oil cooler seals HB1-510-27x35x2.
6.Oil cooler drain gasket Q130101-3
I have checked with Doug on these parts and he is out of stock. If you have any of these parts please contact me off list. Thanks Kelley kelmonroe(at)comcast.net
Noplugs
Posted: Sun Dec 06, 2009 7:21 pm Post subject: Parts needed |
I have some of the things what you.
WL5 Tray, I have a complete loop Antenna, not sure what you meen by "consumtion tank"
PM me if you like.
Mike
--- On Sun, 12/6/09, Kelley Monroe <kelmonroe(at)comcast.net> wrote:
Quote: |
Subject: Parts needed
To: yak-list(at)matronics.com
Date: Sunday, December 6, 2009, 5:25 PM
Quote: |
ollow target=_blank>www.aeroelectric.com
/" rel=nofollow target=_blank>www.buildersbooks.com
ofollow target=_blank>www.homebuilthelp.com
=nofollow target=_blank>http://www.matronics.com/Navigator?Yak-List
et=_blank>http://forums.matronics.com
Posted: Mon Dec 07, 2009 5:01 am Post subject: Parts needed |
The consumption tank is, the center tank in the belly, found in volume 2 page 30 of the parts books. Mike please contact me off list about the parts you have. Thanks Kelley kelmonroe(at)comcast.net (kelmonroe(at)comcast.net)
yakplt(at)yahoo.com Guest
Posted: Mon Dec 14, 2009 9:42 am Post subject: Parts needed |
Wish to purchase:
M-14 propeller oil tube: This tube screws into the front of the engine and is what provides the oil to the hub in order to change prop pitch. Not sure if the same part is used on a Housai, but if it is.... Doug?
Sukhoi Compessor Filter Parts: On the Suke, you have a stainless steel box on the firewall. Inside of it are filters that slide onto a triangular shaft. Need the triangular shaft and the filters.
Please contact me at:
markbitterlich(at)embarqmail.com (markbitterlich(at)embarqmail.com) or
yakplt(at)yahoo.com (yakplt(at)yahoo.com)
If you have these parts, or think you might know where to get them. This is a "big hurry" kind of request for Hubie Tolson.
Mark Bitterlich
dougsappllc(at)gmail.com Guest
Posted: Tue Dec 15, 2009 11:58 am Post subject: Parts needed |
Mark,I have been told that the oil transfer tube is different J9-G1 to V530 prop (it's longer I think), so I don't think I can help. No idea as to the filter. I have them by the gross for the stock Russian or Chinese air compressor, but none like you describe. Sorry.
On Mon, Dec 14, 2009 at 9:38 AM, Yak Pilot <yakplt(at)yahoo.com (yakplt(at)yahoo.com)> wrote:
Quote: |
Wish to purchase:
M-14 propeller oil tube: This tube screws into the front of the engine and is what provides the oil to the hub in order to change prop pitch. Not sure if the same part is used on a Housai, but if it is..... Doug?
Mark Bitterlich
Quote: |
_blank">www.aeroelectric.com
et="_blank">http://www.matronics.com/Navigator?Yak-List
Maybe life is not the party that we were expecting,
but in the mean time, we're here, the band is playing, so we may as well dance....."
Douglas Sapp
Doug Sapp LLC
18B Riverview Road
Omak WA 98841
PH 509-826-4610
Fax 509-826-3644
cpayne(at)joimail.com Guest
Posted: Tue Dec 15, 2009 3:19 pm Post subject: Parts needed |
The Oil supply tubes DO NOT interchange because they are different lengths. The Huosai prop is mounted over a splined shaft that protrudes into the propeller housing, thus it is fairly short. The V530 prop mounts to a flange and needs a rather long oil supply tube to run the depth of the hub.
Threads are the same as well of diameters but that is about it.
Craig Payne
