chuck960
Posted: Mon Jan 25, 2010 9:34 pm Post subject: Brake caliper location |
Looking at some photos it seems that the best location for the brakes are the trailing edge of the gear. This makes the most sense to me. The Grove instructions show them in front and angled down.
Can anyone clarify this? Does the angle make any difference?
Chuck
psm(at)att.net Guest
Posted: Mon Jan 25, 2010 9:49 pm Post subject: Brake caliper location |
Hi Chuck,
I don't think it makes a lot of difference, but I mounted my brake calipers
on the front of the wheel. I chose this position because I was a little bit
concerned about all the junk kicked up by the wheel damaging the caliper. I
think it is less likely to hit the caliper when the caliper is in front.
Paul
XL awaiting upgrade kit
Thruster87
Posted: Tue Jan 26, 2010 1:20 am Post subject: Re: Brake caliper location |
| chuck960 wrote: | Looking at some photos it seems that the best location for the brakes are the trailing edge of the gear. This makes the most sense to me. The Grove instructions show them in front and angled down.
Chuck | Trailing brakes are less likely to end up with unwanted material as it tends to fling it off the disc before it reaches the calipers, whereas leading brakes can pick up /jam with grass etc more easily.But in the end it should make little difference as the clearance between the disc and pads are small. Cheers T87
