by0ung(at)brigham.net Guest
				 Posted: Tue Jan 05, 2010 8:50 am    Post subject: No Title |
				Still, I do like the idea of raising the tail really high (over 10')....if I ever needed to.  Then I could go through the gate without having to just squeeze through.
  Mike Welch
 When you get to the gate take some chalk and mark your tire position,,,  when you are happy with the location,    take a can of spray paint and paint a small dot, or row of dots.
 I would envision a trailer with a long  c  channel for the tail wheel…   lift the tail wheel into the c channel…then push the plane back to the ramps for the main gear, have them  mounted on a pivot, or teeter totter  5 ft on one side 1 ft on the other.    with the plane on the ground the ramp ends would hit the ground,,,,   when the plane is on the trailer,  the wheels would be just past the pivot point of the ramp and hold the ramps off the ground.  You may only have to roll the plane up 4 inches or so for clearance.
 Boyd
