Radiator shutter
jpspencer(at)cableone.net
PostPosted: Wed Dec 16, 2009 4:22 pm    Post subject: Radiator shutter Reply with quote
Well I have gotten tired of fooling with tape to try to keep the coolant and oil temps up and am in the process of building some shutters...anybody else built any?
thx Joe
vgstol(at)bigpond.net.au
PostPosted: Thu Dec 17, 2009 1:03 pm    Post subject: Radiator shutter Reply with quote
About a month ago there was some discussion and photos of a shutter posted on the Rans S7 Yahoo forum.
JG
On Thu, Dec 17, 2009 at 10:14 AM, Joe Spencer <jpspencer(at)cableone.net (jpspencer(at)cableone.net)> wrote:
[quote] Well I have gotten tired of fooling with tape to try to keep the coolant and oil temps up and am in the process of building some shutters...anybody else built any?
thx Joe
_blank">www.aeroelectric.com
ist" target="_blank">http://www.matronics.com/Navigator?Zenith701801-List
tp://forums.matronics.com
dons701
PostPosted: Fri Jan 01, 2010 7:26 am    Post subject: Re: Radiator shutter Reply with quote
On this subject of over cooling the oil, has anyone tried or are using a thermostatic bypass valve ? The oil temp would be regulated within a range that would be suitable in all conditions. I remember seeing this used in the automotive aftermarket. The valve was located in the oil filter mounting adapter and maintains 180 degree oil temp, no shutters needed. Don
Zenith 701 #76120
Jabiru 2200A #2456 95 hours
Sensenich Wood 64-PJ-36 Prop
cscsail(at)gmavt.net
PostPosted: Fri Jan 01, 2010 8:51 am    Post subject: Radiator shutter Reply with quote
Don,
I installed a oil thermostat that I bought from Lockwood. The oil
temperature gets of to 180 deg. in about 10 minutes even on very cold winter
days here in Vermont. It also maintains 180 deg. when flying in temperatures
that are in the minus numbers, something that I don't think would be
possible without it.
"701 912uls on skis"
Gordon
