stevesimmons(at)charter.n Guest
Posted: Mon Dec 28, 2009 12:45 pm Post subject: FWD Battery Location |
Does anyone have a good drawing or photos of a fwd battery instillation on a Kolb mark III Classic?
by0ung(at)brigham.net Guest
Posted: Mon Dec 28, 2009 3:35 pm Post subject: FWD Battery Location |
| Quote: | Does anyone have a good drawing or photos of a fwd battery instillation on a Kolb mark III Classic?
| Quote: | >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>
When I first built my mkIII I put the battery forward of the rudder pedals in order to get the cg closer to the center,,,,, found out that it flies better at the aft edge of the cg range. And when I had 2 people on board and the forward cg battery location I would run out of elevator authority. So I moved the battery to just behind the passenger seat. If I were a light weight pilot, I would build a small compartment in the floor to put in a 10 lb bag of shot when flying solo, and take it out if I had a passenger on board.
Just my $0.02 worth.
Boyd Young
Mkiii 912 ul
bill_joe(at)bellsouth.net Guest
Posted: Mon Dec 28, 2009 4:32 pm Post subject: FWD Battery Location |
Hello Guys, and Happy New-Year to all.
I did the same thing that Boyd did and had the battery in the nose. Well it is behind the pass seat where it is going to stay. I had my wife to sew a vinyl bag that would hold a 40 lb bag of play sand and I just lay it on the floor some times to balance things out. But I think agree with Boyd,put it behind the pass seat.
Bill Futrell
MK111Xtra-812-80 hp
Posted: Mon Dec 28, 2009 5:12 pm Post subject: FWD Battery Location |
I'd never add weight to the nose of a mkIII unless I weighed 75 lbs and flew solo all the time.
The weight and balance for a mkIII is not exactly exact.....
I'm flying with a 12 lb Maule Tundra Tail Wheel, 150 lbs of fuel in a 25 gal tank behind the cg, plus 125 lbs of personal gear behind cg in the cargo bay. I have aft cg, but it is still within the acceptable, safe flying range.
[quote] When I first built my mkIII I put the battery forward of the rudder pedals in order to get the cg closer to the center,,,,, found out that it flies better at the aft edge of the cg range. And when I had 2 people on board and the forward cg battery location I would run out of elevator authority. So I moved the battery to just behind the passenger seat. If I were a light weight pilot, I would build a small compartment in the floor to put in a 10 lb bag of shot when flying solo, and take it out if I had a passenger on board.
Boyd Young
Mkiii 912 ul
_________________ John Hauck
Titus, Alabama |
Richard Pike
Posted: Mon Dec 28, 2009 6:19 pm Post subject: Re: FWD Battery Location |
You guys putting ballast in is why I added the ability to micro-adjust the flaps. By raising or lowering the flaps a very minute amount, you can easily compensate for trim changes that fall outside the factory spring loading arrangement.
Here's the link to the pictures, and obviously I radically changed my flap mechanism, but I was also using this same method of setting the flaps before I totally redid the cross tube.
http://www.bcchapel.org/pages/0003/pg3.htm
Skip the first two pictures on the page and the associated info, that is only for those who want to relocate the whole arrangement. Notice on the next four pictures that I ground off the original side notches and bolted on a curved piece with holes in it for the pin to lock into. You can put the holes where ever you want, and as many or as few as you want.
Richard Pike
MKIII N420P (420ldPoops)
Posted: Mon Dec 28, 2009 6:54 pm Post subject: FWD Battery Location |
-just to be different....My battery is in front of the rudder pedals and I like it just fine. If you want a pic I would have to dig up a photo CD.
BB
faked out with a nice day yesterday but woke back up to (white) reality this morning.
style="color: blue; text-decoration: underline; ">www.aeroelectric.com
href="http://www.buildersbooks.com" style="color: blue; text-decoration: underline; ">www.buildersbooks.com
style="color: blue; text-decoration: underline; ">www.homebuilthelp.com
style="color: blue; text-decoration: underline; ">www.howtocrimp.com
style="color: blue; text-decoration: underline; ">http://www.matronics.com/contribution
style="color: blue; text-decoration: underline; ">http://www.matronics.com/Navigator?Kolb-List
blue; text-decoration: underline; ">http://forums.matronics.com
pj.ladd(at)btinternet.com Guest
Posted: Tue Dec 29, 2009 9:04 am Post subject: FWD Battery Location |
vinyl bag that would hold a 40 lb bag of play sand>>
Jeepers!
If you really need that much ballast i would suspect that something is seriously out of kilter. I have the battery just behind the passenger seat and about 4lbs of lead in the nose. Lateral inbalance caused by flying without a passenger is taken care of by the Hauk bungee design.
Pat
Posted: Tue Dec 29, 2009 9:51 am Post subject: FWD Battery Location |
I have my battery installed in the nose of my MKIIIC. My VW required by the numbers that the battery be moved. My battery is a light 12AH lawn mower battery.
When I installed my first redrive VW engine it was mounted so high that I had seven inches of clearance between the 72 inch prop and the boom tube. My first 150 lb. passenger required me to hold full up elevator to climb with power (not good). For a while I added a steel weight to the tail wheel strut. Later on a cross country I found that the aft CG caused by the tail weight caused the plane to be almost uncontrollable in heavy turbulence. Removing the weight made a significant improvement.
I have since lowered the engine but haven't flown with more than a 160 lb. passenger yet.
Rick Neilsen
Redrive VW Powered MKIIIC
racerjerry
Joined: 15 Dec 2009 Posts: 202 Location: Deer Park, NY
Posted: Wed Dec 30, 2009 7:17 am Post subject: Re: FWD Battery Location |
YUP. If you try to compensate for a high thrust line (nose down-force) with added tail weight, you can quickly get into big trouble. When doing modifications, skipping W & B is not an option.
What was that old saying about tuning 2-cycle racing engines? That they sound best right before they blow up? Yes, the plane flies better with aft CG but going too far brings on stability and stall recovery problems. Don’t exceed the aft CG limit.
_________________ Jerry King |
apilot(at)surewest.net Guest
Posted: Thu Dec 31, 2009 10:17 am Post subject: FWD Battery Location |
Do not have a picture of the forward battery box, but the task was made easier by cutting an access hole in the top of the nose cone with a removeable hatch cover. It is handy for servicing the antenna wiring, the nose ballast and the back of the instrument panel. Vic Mk IIIC
