[Fwd: Aileron deflection]
wdaniell(at)etb.net.co
PostPosted: Fri Jan 01, 2010 9:09 am    Post subject: [Fwd: Aileron deflection] Reply with quote
I have set up my ailerons and everything appears to be fine except that
the left one is +23.5 and - 19 whereas the right is the regulation +23.5
and - 20.
How critical is this?
How did others measure this? I am using an inclinometer at right angles
to the line of the aileron hinges.
Will
grahamsingleton(at)btinte
PostPosted: Fri Jan 01, 2010 3:52 pm    Post subject: [Fwd: Aileron deflection] Reply with quote
Will
I wouldn't worry about it
Graham
that the left one is +23.5 and - 19 whereas the right is the
regulation +23.5 and - 20.
angles to the line of the aileron hinges.
Will
