kevann(at)gotsky.com Guest
Posted: Sat Jan 02, 2010 7:12 am Post subject: oil vent 9xx series engines |
Hello All,
I am looking to reduce the oil on the belly of my plane that comes from the vent tube of my 914. I imagine that some have made a simple air/oil separator? The ones available commercialy are quite pricey and since I am experimental...
Anyone have a simple design?
Happy New Year
Kevin
Europa XS
l_luv2_fly(at)yahoo.com Guest
Posted: Sat Jan 02, 2010 7:37 am Post subject: oil vent 9xx series engines |
Hi Kevin,
I have the same problem. I have some oil separator designs that the Canard guys shared with me, but the general consensus was that oil separators, (homemade or otherwise) don't work that great.
Some of the Canard guys were simply re directing the crank case vent line to point at the exhaust pipe, so when a drip of oil came out, it fell on the outside of the exhaust and simply burned off. I am thinking of trying something like that for my installation.
Cheers, Paul
Subject: oil vent 9xx series engines
Hello All,
lucien
Posted: Sat Jan 02, 2010 7:39 am Post subject: Re: oil vent 9xx series engines |
| kevann(at)gotsky.com wrote: | Hello All,
Happy New Year
Kevin
Europa XS
Just out curiosity, do you know what's causing the venting in the first place? Don't know about the 914, but my 912ULS only vents a whole bunch in case I've overfilled the tank or do a lot of unusual attitude flying. I.e. practicing power-on stalls usually oils up the belly and tail pretty good.....
It should otherwise vent only a very little bit and shouldn't be enough to really oil the plane up.....
LS
_________________ LS
Titan II SS
Posted: Sat Jan 02, 2010 7:55 am Post subject: oil vent 9xx series engines |
Paul McAllister wrote:
| Quote: | Hi Kevin,
Cheers, Paul
Hello mate
don't think I'd do that, better to put it inside the exhaust? If you had
a big leak/vent it might catch fire and oil fires are extremely hard to
put out.
Graham
gfmjr_20(at)hotmail.com Guest
Posted: Sat Jan 02, 2010 10:58 am Post subject: oil vent 9xx series engines |
I run my oil tank vent line into a small plastic bottle (with a vent hole in it) to catch the venting oil. Seem to work in eliminating th mess on the fuse
George May
601XL 912s
Subject: RotaxEngines-List: oil vent 9xx series engines
Date: Sat C 2 Jan 2010 07:11:27 -0800
Hello All C
Happy New Year
Kevin
Europa XS
Hotmail: Free C trusted and rich email s='_new'>Get it now. [quote][b]
Posted: Sat Jan 02, 2010 2:24 pm Post subject: oil vent 9xx series engines |
Hi! Kevin
Watch out you don’t finish up with crank case pressure.
Bob Harrison G-PTAG
From: owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of Kevin Klinefelter
Sent: 02 January 2010 15:11
Hello All,
Happy New Year
Kevin
Europa XS
0123456789
