THE VIRTUE OF SIMPLICITY
racerjerry
PostPosted: Fri Jan 01, 2010 12:20 pm    Post subject: THE VIRTUE OF SIMPLICITY Reply with quote
“Parts left out cost nothing and cause no service problems.” Parts left out also can cause no emergencies or smoke in the cockpit. I believe that the first statement was attributed to GM’s Charles “Boss” Kettering. Henry Ford was a great advocate of the value of simplicity too; whether it be in life, in work or in play. If our missions often involve flying IFR at night, then a very good case can be made for all the backups, added equipment and redundancy advocated in this forum. What concerns me is that all the emergency procedures required to take advantage of redundant systems must be committed to writing and to memory; then must be tested, practiced and periodically rehearsed. With the increased costs of flying, TRUE currency becomes even more elusive. During an emergency, pilots rarely have time to look in their POH for emergency procedures; you will not have time either. When the adrenalin and sweat is flowing and when fear and tunnel vision sets in is not the time to begin learning emergency procedures.
What is your plan to counter smoke in the cockpit? I have a plan. The FAA is currently saying that you need one too.
If 99% of your planned missions are day VFR, think twice or 3 times, before going overboard on adding overly complicated equipment and redundant backup systems, much of which you barely understand. And don’t forget that your airplane will perform better with less weight.
Jerry King
PostPosted: Fri Jan 01, 2010 5:11 pm    Post subject: THE VIRTUE OF SIMPLICITY Reply with quote
"Parts left out cost nothing and cause no service problems." Parts
believe that the first statement was attributed to GM's Charles
"Boss" Kettering. Henry Ford was a . . .
<snip>
CFK is one of my heros. Purty smart fellow . . .
don't forget that your airplane will perform better with less weight.
Dead on right! The simplest, lightest, and most profound
adaptations of legacy TC electrical systems to OBAM aircraft
was the conversion of an "avionics bus" to a "dual feed-path
endurance bus" and replacement of the vacuum pump with an
SD-8. This produced a system for less weight and several-fold
improvement in system reliability. In other words, Z-13/8
gives you system reliability of the system in a King Air but
with the addition of only one switch (S/B Alt Control).
Further, there are NO combinations of mis-positioned switches
that put the system at risk for exacerbating a failure event.
Any contemplated departure from Z-13/8 (or any other Z-figure)
should be evaluated for validity of design goals. I receive
many direct inquiries from folks who say they've read the book,
studied chapter 17 and then ask for an evaluation of their
particular recipe for success. The system generally consists
of cherry-picked features from the Z-figures stirred into their
personal desires/worries.
I have to remind folks that each Z-figure speaks to an
architecture crafted to a design goal. Further, each
drawing as-depicted has a high-order probability of
being the elegant solution for an electrical system in
one aircraft out of 99.9% of OBAM aircraft under
construction.
Adding switches, busses, back-ups to the back-ups and
similar exercises will generally have a poor return on
investment in complexity, weight, and cost-of-ownership.
It's relatively easy to add perceived "enhancements"
but with a risk of inserting new failure modes along
with the certainty of increasing weight, complexity
and cost of ownership. But as Jerry pointed out, ideas
that seem to add comfort for perceived concerns may
backfire by adding complexity that the pilot has to
sort out when things are NOT going well in the
cockpit.
I've written extensively about dark-n-stormy night
stories that offer little in the way of understanding
while generating new worries amongst those who
have the least understanding of how the system works.
So just a friendly heads-up for those working on
progressive evolution of the z-figures: If your
design goal is to embark upon a new expedition
into experimentation, you're certainly free to do
so. We are, after all building EXPERIMENTAL airplanes
. . . or are we?
On the other hand, if one desires to tap the collective
knowledge, understanding and willingness here on the
List to teach, then consider questioning any perceived
shortfall in the Z-figures before you spend a lot of
$time$ cutting and pasting. The majority of folks
on the List are interested in seeing just how FEW parts
we can assemble in the MOST elegant combination to
MAXIMIZE failure tolerance of your project's electrical
system.
ralphmariafinch(at)gmail.
PostPosted: Sat Jan 02, 2010 10:11 am    Post subject: THE VIRTUE OF SIMPLICITY Reply with quote
To play the part of the loyal opposition:
Yes, but.
Do any of us really want to depend on one of the old cars for daily transportation? I have memories, almost all bad, of the old clunkers. I love my modern autos, turn the switch and they start and run. Oil changes at greatly increased intervals, hardly any "tune-ups" and such.
Our lives would be simpler without building airplanes, dealing with computers, and so forth. But by definition those reading this are doing those things and other non-simple chores and hobbies.
To airplanes. Day VFR implies no lights, even no radios. Stay out of Class B and no transponder required. My build is delayed considerably by adding lights and such but I want them. I'll also have an EFIS and autopilot because I think they nice and a good convenience.
These are, after all, experimental. Experiment as you wish. Let's just be aware of all the costs of adding equipment.
BTW, I'm flying an Aircoupe now. When my RV-9A is finished I don't think I'll notice a few extra pounds in comparison...and besides, most of us Americans could easily make up for added equipment weight by losing our spare tires Wink
Ralph Finch
Davis, California
RV-9A QB-SA
PostPosted: Mon Jan 04, 2010 12:55 pm    Post subject: THE VIRTUE OF SIMPLICITY Reply with quote
At 12:10 PM 1/2/2010, you wrote:
<ralphmariafinch(at)gmail.com>
Yes, but.
How does "simplicity" translate into "old" hardware or
degraded service life?
<snip>
I think you missed the significance. The kind of
simplicity we strive for is the minimum cost, parts count,
weight and therefore maximum reliability of any one
system. If your design goals call for lots of bells
and whistles in your airplane, the minimalist rule
for selection of systems suggests that those accessories
with fewest components while meeting design goals are
a better value.
I'm having a good time designing accessories
with micro-controllers where software replaces a bucket-load
of components while allowing me to do more with fewer
parts. Capability goes up while parts count goes down.
I think this tread got started with a List member's
notions of adding more busses and switches to Z-13/8
followed by questions of design goals to be met
while doing so.
PostPosted: Mon Jan 04, 2010 6:07 pm    Post subject: THE VIRTUE OF SIMPLICITY Reply with quote
system.
I think you missed my point. For example, the OP equated simplicity with
less weight, which might be literally true but is irrelevant, because the
weight saved is probably trivial. That's a notion from value
engineering...those evil and arrogant engineers again.
Minimum cost? Minimum parts count? Really? The least cost, greatest
simplicity, maximum safety, minimum parts count, and least weight, is...no
plane at all. Seriously. Absurd? Probably, but it makes the point that it's
foolish to use "minimum", "maximum", and similar extreme or unbalanced terms
in a discussion like this.
No. Don't be silly. My design goals include better reliability, ease of use,
and maintenance than certificated aircraft, balanced with cost
considerations. To achieve those goals I will use modern systems where I
think appropriate. It doesn't include gizmotrons for the sake of gadgetry,
or saving a few pounds because the "airplane will perform better". Other
friends of mine have different goals, or perhaps the same goals but
different decisions to arrive at the same goals.
I'm sincerely glad to hear this. I would be quite interested if you
provided lessons in two related areas:
1. How to design the few conventional electrical parts a microcontroller
needs, that is, the resistors, inductors, caps and perhaps transistor or two
needed.
2. Basic programming of a microcontroller. I'm comfortable with programming
several high-level languages, and years ago knew some assembly, but a class
or lessons would be great. I'd be very willing to pay for a well-designed
set of lessons for this knowledge.
At this time--a couple of years before I actually must decide--I intend to
use Vertical Power's electrical system to wire my aircraft. Many
electromechanical devices are replaced with a few solid-state devices and
software...approaching what cars have had for decades. I consider it a
significant step towards greater simplicity, fewer parts, less weight, and
greater reliability. Of course many differ. I know builders who consider
round gages the way to go for greater reliability; to each their own in the
OBAM world.
while doing so.
I'll take your word for it. The OP's post didn't say anything about that.
BTW Bob, have you thought about memristors, and how they might change
electrical/electronic design (not just for aircraft systems, but in
general). They are the fourth, long forgotten basic electrical component,
just now coming into practical use. I wonder how much of a change in design
and future device capability they might start.
__________ Information from ESET Smart Security, version of virus signature
database 4742 (20100104) __________
The message was checked by ESET Smart Security.
