frank.goodnight(at)att.ne Guest
Posted: Sat Jan 02, 2010 2:04 pm Post subject: MV 2110 Trip |
To Wil Uribe Request for info:
Wil , I plan to fly from Brownsville , TX to MV this year, Would you
please contact me off list , so I can question you about the best
route from
somewhere around EL Passo, and what problems I might expect? My first
time but I have been told you have made the trip several times in your
firestar.
Frank Goodnight THANKS
Firestar 2
Brownsville , TX
frank.goodnight(at)att,net
russkinne(at)mac.com Guest
Posted: Mon Jan 04, 2010 8:23 am Post subject: MV 2110 Trip |
Frank
I see you're planning a big XC trip -- that's great! It's a
wonderful thing to experience in a small plane -- a Kolb should be
ideal.
I've done a lot in Cessnas but smaller would be more fun. I'm sure
your fellow Kolbers will give you detailed advice. Ľou prolly know
most of this already, but in general -- I like to keep a big
Interstate within sight if not within reach, exp. at night. But
then, Kolbs can land most anywhere. I check the winds aloft & plan
my cruising altitudes. Headwinds will be weaker close to the ground
but the air is rougher. Often a choice between flying low, making
good time and getting bounced around; and flying higher, comfortably
but more slowly. I often alternate when I get tired of flying in
rough air.
I'd suggest carrying a can of fire-inflater; doesn't weigh much and
can be invaluable. I also carry a small fire-extinguisher, and ALWAYS
a bottle of water or juice. When empty it can be an emergency urinal
too. Snapple is a good size. Duct tape too, but better yet is ripstop
parachute/spinnaker mending tape; 2" wide and even in jazzy colors.
Survival gear?- as much as you have room for. At least matches, a
good knife or two, and vise-grips. And a signalling mirror.
For planning I usually follow the Interstates. They put them in the
lowest passes thru the mountains.
You'll get lots of advice on all this! -- John H is the expert.
And you'll have a marvellous time. I'm jealous.
Fair winds,
Russ K
On Jan 2, 2010, at 5:04 PM, frank.goodnight wrote:
<frank.goodnight(at)att.net>
you please contact me off list , so I can question you about the
best route from
first time but I have been told you have made the trip several
times in your firestar.
Firestar 2
Brownsville , TX
Posted: Mon Jan 04, 2010 3:52 pm Post subject: MV 2110 Trip |
Hi Russ,
Thanks for your thoughts, I am going to add some sailcloth tape to my
fly away kit , seems like it's necessary that I rip a hole in my
fabric at least once a week. I've been
using Gorilla brand duct tape, the wide stuff, works good but I bet
your idea is better.
I've been a pilot for a long time , but have done very little flying
in the last 30 years [ no airplane ] . What little flying I have done
has been ,around the patch , sunday afternoon,
in good weather. My x country time is zero , I'm excited about the
upcoming trip , but also nervous . Anything that you or anyone else
can tell me that would make the trip
safer or more enjoyable I would sure like to hear. I believe the more
knowledge I'm exposed to and the more options I have the better off I
am, if some of it is redundant
info , so what can't hurt a thing.
Frank Goodnight
Firestar2
HKS engine 120 hrs
Brownsville , TX
On Jan 4, 2010, at 8:58 AM, russ kinne wrote:
Frank
ideal.
rough air.
ALWAYS a bottle of water or juice. When empty it can be an emergency
urinal too. Snapple is a good size. Duct tape too, but better yet is
ripstop parachute/spinnaker mending tape; 2" wide and even in jazzy
colors. Survival gear?- as much as you have room for. At least
matches, a good knife or two, and vise-grips. And a signalling mirror.
Fair winds,
Russ K
> best route from
> Firestar 2
> Brownsville , TX
> Do not archive
Posted: Mon Jan 04, 2010 6:31 pm Post subject: MV 2110 Trip |
| Quote: | upcoming trip , but also nervous . Anything that you or anyone else can
Frank Goodnight
Frank G/Gang:
I've been flying Kolbs cross country for a while.
When I decided to start flying extremely long, multi-day/week cross
countries, I decided to do an overnight flight to check if I had everything
I needed and determine things that I did not need.
This first overnight flight confirmed what I needed to take with me on the
longer flights.
The primary requirement for me is to be comfortable and get a good night's
sleep. I have to have a good tent that has been tested in wet and windy
weather, a good Thermarest air mattress, pillow, sleeping bag, etc. I have
the luxury of more cargo space than you do, so you may not want to bring a
pillow, but use your dirty clothes bag for a pillow.
The best way to know what it is going to take for you is to get out there
and do overnight cross country flights. If you can be comfortable for one
night, you should be comfortable for a month or more.
It takes as much preparation for a one night flight as it does for a 30
night flight.
_________________ John Hauck
Titus, Alabama |
