YAK 50 Spar attachment bracket.
aerostar6
PostPosted: Fri Jan 08, 2010 12:01 pm    Post subject: YAK 50 Spar attachment bracket. Reply with quote
Hello all from a snowy England.
Our YAK 50 is on annual at the moment, and our engineers have found inter-granular corrosion in the material of the REAR RIGHT spar attachment bracket, and it is going to have to be replaced.
Does anyone out there in the Yak community have such a part or are aware of a scrap airframe where the bracket could be liberated?
Fabrication is our fall back option, but unfortunately we can't paint 'EXPERIMENTAL' on the side and get on with it! Our feds will take an age to approve a new build part (despite its simplicity), so an existing part is preferred.
Many thanks.
Mark Levy
aerostar6
PostPosted: Mon Jan 11, 2010 3:41 am    Post subject: Re: YAK 50 Spar attachment bracket. Reply with quote
Here is a poor quality catalogue photo of the part required. Better quality one to follow.
Yak 50 attachment bracket.pdf
 Filename:  Yak 50 attachment bracket.pdf
 Filesize:  8.37 KB
 Downloaded:  358 Time(s)
jan.mevis(at)informavia.b
PostPosted: Mon Jan 11, 2010 4:41 am    Post subject: YAK 50 Spar attachment bracket. Reply with quote
I would try to make it, and convince the CAA that it's at least as good as
the original part. Can't you have it made by a company who can certify it
with an EASA document?
Jan
YK50 RA2005K
