smokyray(at)rocketmail.co Guest
Posted: Thu Jan 07, 2010 10:12 am Post subject: Rocket Efficiency, Defined! |
Guys,
More on a Rocket note, I am constantly amazed by the capabilities of this little machine. Coming home from Dallas post-Christmas I looked at forecast winds and thought I would try to one hop it home, nearly 800NM and really get some efficiency numbers. With 54 gallons of 100LL on board( 10 gallon aux tanks) I launched, cruise climbed to 11,500 and after letting my Ly-Con built IO-540 with GAMI injectors settle down I began to lean to 50 Degrees LOP and 33 degrees advance on my EI. With just under 20" MP and 2375 RPM I consistently showed 10.4 GPH at 235 Knots GS, a nice tailwind indeed. Being a Saturday and knowing the Whiskey areas would be cold I requested direct to home, straight over the Golfo De Mexico, went on O2 and climbed to 15,500 increasing my GS to 252 knots retaining the same FF. When I finally began my descent into the swamp I still had nearly 20 gallons of fuel on board, landing on my 1500 ft grass strip with 16 gallons left. My Rocket is definitely not the fastest on the block with my oversize tires, caked mud and large tailwheel dragging in the breeze, but it truly shows what John's design is capable of.
BTW, the tach almost clicked over 1000 hours as I flew over the house, looking forward to several thousand more!
Rob "Smokey" Ray
HR2
--- On Wed, 1/6/10, nico css <nico(at)cybersuperstore.com> wrote:
Subject: FW: What was the slowest you ever flew the Blackbird?(MWH)
To: "'nico'" <nico(at)nicsysco.com>
Date: Wednesday, January 6, 2010, 6:29 PM
--> Rocket-List message posted by: "nico css" <[url=/mc/compose?to=nico(at)cybersuperstore.com]nico(at)cybersuperstore.com[/url]>
Brian Shul, Retired SR-71 Pilot via Plane and Pilot Magazine.
As a former SR-71 pilot, and a professional keynote speaker, the question
I'm most often asked is "How fast would that SR-71 fly?" I can be assured of
hearing that question several times at any event I attend. It's an
interesting question, given the aircraft's proclivity for speed, but there
really isn't one number to give, as the jet would always give you a little
more speed if you wanted it to. It was common to see 35 miles a minute.
Because we flew a programmed Mach number on most missions, and never wanted
to harm the plane in any way, we never let it run out to any limits of
temperature or speed. Thus, each SR-71 pilot had his own individual "high"
speed that he saw at some point on some mission. I saw mine over Libya when
Khadafy fired two missiles my way, and max power was in order.
Let's just say that the plane truly loved speed and effortlessly took us to
Mach numbers we hadn't previously seen.
So it was with great surprise, when at the end of one of my presentations,
someone asked, "what was the slowest you ever flew the Blackbird?"
This was a first.
After giving it some thought, I was reminded of a story that I had never
shared before, and relayed the following.
I was flying the SR-71 out of RAF Mildenhall, England, with my back-seater,
Walt Watson; we were returning from a mission over Europe and the Iron
Curtain when we received a radio transmission from home base. As we scooted
across Denmark in three minutes, we learned that a small RAF base in the
English countryside had requested an SR-71 fly-past. The air cadet commander
there was a former Blackbird pilot, and thought it would be a motivating
moment for the young lads to see the mighty SR-71 perform a low approach. No
problem, we were happy to do it. After a quick aerial refueling over the
North Sea, we proceeded to find the small airfield.
Walter had a myriad of sophisticated navigation equipment in the back seat,
and began to vector me toward the field. Descending to subsonic speeds, we
found ourselves over a densely wooded area in a slight haze. Like most
former WWII British airfields, the one we were looking for had a small tower
and little surrounding infrastructure. Walter told me we were close and that
I should be able to see the field, but I saw nothing. Nothing but trees as
far as I could see in the haze.
We got a little lower, and I pulled the throttles back from 325 knots we
were at. With the gear up, anything under 275 was just uncomfortable. Walt
said we were practically over the field-yet; there was nothing in my
windscreen. I banked the jet and started a gentle circling maneuver in hopes
of picking up anything that looked like a field. Meanwhile, below, the cadet
commander had taken the cadets up on the catwalk of the tower in order to
get a prime view of the fly-past. It was a quiet, still day with no wind and
partial gray overcast.
Walter continued to give me indications that the field should be below us
but in the overcast and haze, I couldn't see it. The longer we continued to
peer out the window and circle, the slower we got. With our power back, the
awaiting cadets heard nothing. I must have had good instructors in my flying
career, as something told me I better cross-check the gauges.
As I noticed the airspeed indicator slide below 160 knots, my heart stopped
and my adrenalin-filled left hand pushed two throttles full forward. At this
point we weren't really flying, but were falling in a slight bank.
Just at the moment that both afterburners lit with a thunderous roar of
flame (and what a joyous feeling that was) the aircraft fell into full view
of the shocked observers on the tower. Shattering the still quiet of that
morning, they now had 107 feet of fire-breathing titanium in their face as
the plane leveled and accelerated, in full burner, on the tower side of the
infield, closer than expected, maintaining what could only be described as
some sort of ultimate knife-edge pass.
Quickly reaching the field boundary, we proceeded back to Mildenhall without
incident. We didn't say a word for those next 14 minutes.
After landing, our commander greeted us, and we were both certain he was
reaching for our wings. Instead, he heartily shook our hands and said the
commander had told him it was the greatest SR-71 fly-past he had ever seen,
especially how we had surprised them with such a precise maneuver that could
only be described as breathtaking. He said that some of the cadet's hats
were blown off and the sight of the plan form of the plane in full
afterburner dropping right in front of them was unbelievable.
Walt and I both understood the concept of "breathtaking" very well that
morning, and sheepishly replied that they were just excited to see our low
approach.
As we retired to the equipment room to change from space suits to flight
suits, we just sat there-we hadn't spoken a word since "the pass."
Finally, Walter looked at me and said, "One hundred fifty-six knots. What
did you see?" Trying to find my voice, I stammered, "One hundred fifty-two."
We sat in silence for a moment. Then Walt said, "Don't ever do that to me
again!"
And I never did.
A year later, Walter and I were having lunch in the Mildenhall Officer's
club, and overheard an officer talking to some cadets about an SR-71
fly-past that he had seen one day. Of course, by now the story included kids
falling off the tower and screaming as the heat of the jet singed their
eyebrows.
Noticing our HABU patches, as we stood there with lunch trays in our hands,
he asked us to verify to the cadets that such a thing had occurred.
Walt just shook his head and said, "It was probably just a routine low
approach; they're pretty impressive in that plane."
Impressive indeed.
Little did I realize after relaying this experience to my audience that day
that it would become one of the most popular and most requested stories.
It's ironic that people are interested in how slow the world's fastest jet
can fly. Regardless of your speed, however, it's always a good idea to keep
that cross-check up, and keep your Mach up, too.
nbsp; --> http://www.matronics.com/Navigator?Rocket-List
_sp; --> h - List Contribution Web Site; &nb; http:========================
| | - The Matronics Rocket-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
jrstone(at)insightbb.com Guest
Posted: Thu Jan 07, 2010 2:13 pm Post subject: Rocket Efficiency, Defined! |
Nice!!
Jim Stone
Louisville
Lee Logan
Posted: Thu Jan 07, 2010 4:00 pm Post subject: Rocket Efficiency, Defined! |
Great report, Smokey. An amazing airplane, indeed!
Lee...
P.S. Festus and his gang spent the holidays with us. Spun him around the field in my F1, had a great time!
andrew(at)nzactive.com Guest
Posted: Thu Jan 07, 2010 10:03 pm Post subject: Rocket Efficiency, Defined! |
Couldn't agree more Smokey - I've flown a bunch of different aircraft, but nothing, NOTHING, can touch my Rocket. Except another Rocket, and some of you guys seem to have slightly faster ones than I do - I true out at max cruise (2500 rpm, max throttle, 5000-10,000 feet) at exactly 200 knots, and I've heard some people true out at 205, even 210? Is that true, anyone?
And as you say the speed/economy equation is extraordinary - not to mention, the pretty damn good "go-slow" STOL capabilities too.
Only tiny Q I have is that I was under the impression that the best economy comes from lower RPMs, partly or wholly cos of the internal friction of the engine. I wonder if you would have got even better figures at, say, 22" MP and 2000 rpm? Or whatever the lowest RPM limit is, for your engine...? I believe that is the main "trick" that Lindbergh taught the aviators of the US Navy & Marine Corps in the Pacific, back in '44 or so, when he was sent over to teach them to get maximum range and endurance from their steeds.
not trying to argue, just thought I'd mention it. Your basic point - that rockets rock - is pretty indisputable I reckon
Andrew
From: owner-rocket-list-server(at)matronics.com [mailto:owner-rocket-list-server(at)matronics.com] On Behalf Of Rob Ray
Sent: Friday, January 08, 2010 7:31 AM
To: rocket-list(at)matronics.com
Subject: Rocket Efficiency, Defined!
Guys,
Rob "Smokey" Ray
HR2
--> Rocket-List message posted by: "nico css" <nico(at)cybersuperstore.com (nico(at)cybersuperstore.com)>
This was a first.
approach.
again!"
And I never did.
eyebrows.
Impressive indeed.
href="http://www.matronics.com/Navigator?Rocket-List">http://www.matronhref="http://forums.matronics.com">http://forums.matronics.com
nico(at)cybersuperstore.c Guest
Posted: Thu Jan 07, 2010 11:01 pm Post subject: Rocket Efficiency, Defined! |
From what I know, the better fuel economy at lower RPM's is due to less air being pumped per minute. Theoretically, an engine working at 1,000 rpm as apposed to 3,000 rpm, just as an example, pumps 1/3rd of the air, which has a greater impact on the fuel burn even at higher mixture settings due to higher MP's. The net gain is positive at lower RPM's. There would be, I assume, an envelope in which that is true, in theory.
Just my 2c worth.
Nico
From: owner-rocket-list-server(at)matronics.com [mailto:owner-rocket-list-server(at)matronics.com] On Behalf Of ACTIVE NZ - Andrew
Sent: Thursday, January 07, 2010 10:01 PM
Subject: RE: Rocket Efficiency, Defined!
Andrew
Guys,
Rob "Smokey" Ray
HR2
This was a first.
approach.
again!"
And I never did.
eyebrows.
Impressive indeed.
fairlea(at)amtelecom.net Guest
Posted: Fri Jan 08, 2010 8:11 am Post subject: Rocket Efficiency, Defined! |
Andrew
I have been flying rockets for twelve years now and have been fortunate to have flown many different versions. All of them fly beautifully and I can honestly say that if I had to go back to other types of aircraft I probably would not fly very much. The last three years I have participated in a few events held by the Sport Aircraft Racing League, SARL, http://sportairrace.org/index.html . It has been a real learning experience and with constant experimentation I have increased the top speed of my aircraft considerably. The average top speed, full power, in three races this year was 220.2 knots. This was full throttle, 2650rpms.
In the same three races Wayne Hadath with a stock engine, and a clean light stock F1 had a 212 knot average. The fastest RV8 is currently owned by John Huft, and he is right around the 200 knot range with his beautiful aircraft.
I would encourage other rocket owners to participate in these events, experiment with your aircraft and find some different ways to get these amazing aircraft even faster. With gains in top speed, comes gains in efficiency which you will use on each and every flight.
Tom Martin
Sent: January 8, 2010 1:01 AM
Andrew
Guys,
Rob "Smokey" Ray
HR2
This was a first.
approach.
again!"
And I never did.
eyebrows.
Impressive indeed.
| Quote: | | href="http://www.matronics.com/Navigator?Rocket-List">http://www.matronhref="http://forums.matronics.com">http://forums.matronics.comhref="http://www.matronics.com/contribution">http://www.matronics.com/c http://www.matronics.com/Navigator?Rocket-Listhttp://www.matronics.com/contribution |
Checked by AVG.
Checked by AVG.
Posted: Fri Jan 08, 2010 8:44 am Post subject: Rocket Efficiency, Defined! |
G'day Andy,
I too am a big fan of Charles Lindberg and will have to test his P-38 leaning technique sometime. When I knock around here locally I set 20/20 below 5000 ft msl and nomalky show 6 gph at 125 knots, counting the big Hartzell blades as they pass by:) Even more amazing is comparing my RV4 fuel logs from the past on identical trips with the HR2, equal or less at 30 knots faster!
Smokey
On Jan 8, 2010, at 1:00 AM, "ACTIVE NZ - Andrew" <andrew(at)nzactive.com (andrew(at)nzactive.com)> wrote:
[quote] Couldn't agree more Smokey - I've flown a bunch of different aircraft, but nothing, NOTHING, can touch my Rocket. Except another Rocket, and some of you guys seem to have slightly faster ones than I do - I true out at max cruise (2500 rpm, max throttle, 5000-10,000 feet) at exactly 200 knots, and I've heard some people true out at 205, even 210? Is that true, anyone?
Andrew
From: owner-rocket-list-server(at)matronics.com (owner-rocket-list-server(at)matronics.com) [mailto:owner-rocket-list-server(at)matronics.com] On Behalf Of Rob Ray
To: [url=mailto:rocket-list(at)matronics.com]rocket-list(at)matronics.com (rocket-list(at)matronics.com)[/url]
Guys,
Rob "Smokey" Ray
HR2
--- On Wed, 1/6/10, nico css <nico(at)cybersuperstore.com (nico(at)cybersuperstore.com)> wrote:
From: nico css <nico(at)cybersuperstore.com (nico(at)cybersuperstore.com)>
To: "'nico'" <nico(at)nicsysco.com (nico(at)nicsysco.com)>
--> Rocket-List message posted by: "nico css" <[url=mailto:nico(at)cybersuperstore.com]nico(at)cybersuperstore.com (nico(at)cybersuperstore.com)[/url]>
This was a first.
approach.
again!"
And I never did.
eyebrows.
Impressive indeed.
[/url] | [url=http://www.matronics.com/contribution]
[/url]
Posted: Fri Jan 08, 2010 8:45 am Post subject: Rocket Efficiency, Defined! |
Awesome!
On Jan 7, 2010, at 6:11 PM, Lee Logan <leeloganster(at)gmail.com (leeloganster(at)gmail.com)> wrote:
[quote]Great report, Smokey. An amazing airplane, indeed!
Lee...
mcculleyja(at)starpower.n Guest
Posted: Fri Jan 08, 2010 9:42 am Post subject: Rocket Efficiency, Defined! |
I have found that the low RPM cruise choice does exactly what you have
described, primarily due to lower internal engine friction and somewhat
higher prop efficiency due to greater prop blade efficiency. Possibly,
the lower piston speed during the power stroke may provide more complete
combustion, particularly with slightly advanced ignition timing.
I regularly fly cruise at 1900 RPM and anything up to 22 or 23 inches
MAP depending on altitude and temperature with my LYC O-360 and Hartzell
constant speed prop. And with lean of peak operation I get up to 29-30
miles per gallon. In some cases, this allows non-stop flights that take
less flight time than the total elapsed time required by going faster
and having to make an enroute fuel stop. This is a winner on fuel costs,
time, and extended TBO possibilities!
Jim McCulley
ACTIVE NZ - Andrew wrote: ((SNIP))
| Quote: | Only tiny Q I have is that I was under the impression that the best
maximum range and endurance from their steeds. ((SNIP))
Posted: Sat Jan 09, 2010 12:52 am Post subject: Rocket Efficiency, Defined! |
Nice info, y'all.
Unfortunately, being in NZ, I can't participate in these sorts of things. Only two Rockets flying in NZ, that I know of - and another being built.
I'd love to get another 10 knots or so out of my Rocket. I've noticed that she flies with a LOT of down elevator (ie, forward stick) in the cruise, and have wondered about resetting the incidence of the tail plane. She also needs a little left aileron to fly straight, and this means both ailerons are always *slightly* defected. Are these sorts of things likely to rob serious speed? (As in, I don't care about 1-2 knots, but 10 or so, and I'd do something about it.
Would also be interested in the perspective of knowledgeable builder pilots - I've heard of at least one Rocket fatality where the tail came apart, and I'm told Mr Vans disapproves of our aircraft cos they're being pushed beyond design limits. Is there anything in this? As in, would it be worth dismantaling the horizontal and vertical stabs, and rebuilding with thicker gauge steel? I know it's a big job.
Any 'easy' ideas for speeding up Rockets? I've got 280 hp, and she's reasonably light, but does have some avionics of course. Not too many aerials etc. Feel free to contact off list - andrew at activenewzealand dot com.
Cheers
Andrew
ernest(at)flmitigation.co Guest
Posted: Sat Jan 09, 2010 7:53 am Post subject: Rocket Efficiency, Defined! |
Hey Andrew,
I didn’t build my Rocket and am not inclined in that way so have not input to your questions. I did want to say that I have the same issues with my Rocket, I have pretty much full down elevator in cruise, and my plane is left wing heavy, I have been trying to figure out a way to get the wing issue worked out, nothing good yet. Haven’t gone into the tail issue but have wondered how much speed I am loosing, I am sure it is substantial.
Looking forward to the answers.
Ernest
N540HB
On 1/9/10 3:27 AM, "ACTIVE NZ - Andrew" <[url=andrew(at)nzactive.com]andrew(at)nzactive.com[/url]> wrote:
[quote]Nice info, y'all.
Cheers
Andrew
Posted: Sat Jan 09, 2010 8:02 am Post subject: Rocket Efficiency, Defined! |
Tom and others,
Have you ever noticed your Rocket yaws when you fly into the clouds. I got significant vertigo the first few times I went IMC and then figured out why. I noticed as I flew into the clouds my inner ear sensed a 30 deg left bank but the aircraft remained wings level. I noticed the ball was out to the left and when I centered it, my vertigo went away. Question, what the heck is causing the ball to slide left when flying into the clouds? Btw, I have a plastic wedge on the left side of the rudder which centers the ball in cruise flight, I suspect airflow over it changes as the air density changes when flying into the clouds. Anyone else experience such a strange phenomenon? Have an explanation?
Jim Stone
Louisville KY
275 Hours
Posted: Mon Jan 11, 2010 8:44 am Post subject: Rocket Efficiency, Defined! |
G'day again Andy,
To answer your question, yes, I have LR tanks, a design identical to Hotel Whiskey Aviation's (Safe Air One) tanks that slide through the lightening holes in the wing forward of the spar with the largest portion inside the tip, five gallons each for a total capacity of 54 gallons. Mine utilize a check valve which requires no separate valves, settings, pumps or otherwise to drain, gravity and vent pressure drain them dry every time.
Maximum range cruise I have tried many settings but 20"/2350 RPM between 8500 and 10500 feet 50 LOP and 33 degrees advance with the GAMI injectors seems to deliver the best speed/economy. This equates to 10.5 GPH at 183 Knots TAS. On one occasion searching for a lost child in the swamp I set 20/20 leaned to peak and saw 6.5 GPH at 125 knots flying search patterns for over five hours and and still had enough fuel left to fly 200NM home at high cruise!
Your mileage may vary:)
Smokey
HR2
--- On Sat, 1/9/10, Jim Stone <jrstone(at)insightbb.com> wrote:
Subject: Re: Rocket Efficiency, Defined!
Date: Saturday, January 9, 2010, 7:57 AM
Tom and others,
Jim Stone
Louisville KY
275 Hours
Posted: Mon Jan 11, 2010 11:13 am Post subject: Rocket Efficiency, Defined! |
Did you guys find the kid?
Sent: Monday, January 11, 2010 8:23 AM
G'day again Andy,
Smokey
HR2
Subject: Re: Rocket-List: Rocket Efficiency, Defined!
UNKNOWN { FONT-FAMILY: Tahoma; panose-1: 2 11 6 4 3 5 4 4 2 4 } #yiv304304449 #yiv304304449 P.MsoNormal { MARGIN: 0cm 0cm 0pt; FONT-FAMILY: "Times New Roman"; FONT-SIZE: 12pt } #yiv304304449 LI.MsoNormal { MARGIN: 0cm 0cm 0pt; FONT-FAMILY: "Times New Roman"; FONT-SIZE: 12pt } #yiv304304449 DIV.MsoNormal { MARGIN: 0cm 0cm 0pt; FONT-FAMILY: "Times New Roman"; FONT-SIZE: 12pt } #yiv304304449 A:link { COLOR: blue; TEXT-DECORATION: underline } #yiv304304449 SPAN.MsoHyperlink { COLOR: blue; TEXT-DECORATION: underline } #yiv304304449 A:visited { COLOR: blue; TEXT-DECORATION: underline } #yiv304304449 SPAN.MsoHyperlinkFollowed { COLOR: blue; TEXT-DECORATION: underline } #yiv304304449 PRE { MARGIN: 0cm 0cm 0pt; FONT-FAMILY: "Courier New"; FONT-SIZE: 10pt } #yiv304304449 SPAN.EmailStyle18 { FONT-FAMILY: Arial; COLOR: navy } UNKNOWN { MARGIN: 72pt 90pt } #yiv304304449 DIV.Section1 { } Tom and others,
Jim Stone
Louisville KY
275 Hours
Posted: Mon Jan 11, 2010 8:59 pm Post subject: Rocket Efficiency, Defined! |
Thx for the info, y'all. Will seriously consider prop upgrade at overhaul time. Or before An extra 10 knots would be marvellous!
Andrew
Sent: Tuesday, January 12, 2010 6:00 AM
G'day again Andy,
Smokey
HR2
UNKNOWN { FONT-FAMILY: Tahoma; panose-1: 2 11 6 4 3 5 4 4 2 4 } #yiv304304449 #yiv304304449 P.MsoNormal { FONT-SIZE: 12pt; MARGIN: 0cm 0cm 0pt; FONT-FAMILY: "Times New Roman" } #yiv304304449 LI.MsoNormal { FONT-SIZE: 12pt; MARGIN: 0cm 0cm 0pt; FONT-FAMILY: "Times New Roman" } #yiv304304449 DIV.MsoNormal { FONT-SIZE: 12pt; MARGIN: 0cm 0cm 0pt; FONT-FAMILY: "Times New Roman" } #yiv304304449 A:link { COLOR: blue; TEXT-DECORATION: underline } #yiv304304449 SPAN.MsoHyperlink { COLOR: blue; TEXT-DECORATION: underline } #yiv304304449 A:visited { COLOR: blue; TEXT-DECORATION: underline } #yiv304304449 SPAN.MsoHyperlinkFollowed { COLOR: blue; TEXT-DECORATION: underline } #yiv304304449 PRE { FONT-SIZE: 10pt; MARGIN: 0cm 0cm 0pt; FONT-FAMILY: "Courier New" } #yiv304304449 SPAN.EmailStyle18 { COLOR: navy; FONT-FAMILY: Arial } UNKNOWN { MARGIN: 72pt 90pt } #yiv304304449 DIV.Section1 { } Tom and others,
Jim Stone
Louisville KY
275 Hours
