Posted: Mon Jan 11, 2010 2:37 pm Post subject: IO 540 motor oil? |
In doing my cowl fitting it was necessary to rotate my three bladed prop. I pulled the bottom plugs and had a significant amount of the motor oil containing the anti corrosion additive out of #1 and #3 cylinders.
I just got a sample of the Cortec VC1-326 additive but can someone tell me what motor oil the engine normally uses. My engine manual is behind a pile of stuff which I cannot get out of the way right now.
John
ricksked(at)cox.net Guest
Posted: Mon Jan 11, 2010 3:11 pm Post subject: IO 540 motor oil? |
Mineral oil
Sent via BlackBerry by AT&TFrom: John Gonzalez <indigoonlatigo(at)msn.com>
Date: Mon, 11 Jan 2010 14:32:33 -0800
To: RV 10 group<rv10-list(at)matronics.com>
Subject: RV10-List: IO 540 motor oil?
In doing my cowl fitting it was necessary to rotate my three bladed prop. I= pulled the bottom plugs and had a significant amount of the motor oil cont= aining the anti corrosion additive out of #1 and #3 cylinders.
 =3B
I just got a sample of the Cortec VC1-326 additive but can someone tell me = what motor oil the engine normally uses. My engine manual is behind a pile = of stuff which I cannot get out of the way =3Bright now.
 =3B
 =3B
John
= [quote][b]
AirMike
Posted: Tue Jan 12, 2010 11:03 am Post subject: IO 540 motor oil? |
Per Ricksked if the engine is new you MUST use straight Mineral Oil per Lycoming's specs until "the oil consumption stabilizes". Get it from your local FBO, Spruce, or Chief Aircraft. Be sure to drain all of the preservative oil from the engine first.
_________________ See you OSH '18
Q/B - sold. |
Posted: Tue Jan 12, 2010 12:34 pm Post subject: IO 540 motor oil? |
I spoke to Lycoming's Bart C He then spoke to the tech department. He said that the Cortec VC1-326 could be added to a 20w-50 mineral engine oil in a 1 to 10 ratio. I will be using a syringe to fill the two cylinders that lost the oil whan I removed the lower plugs.
| Quote: | Subject: Re: IO 540 motor oil?
Date: Tue C 12 Jan 2010 11:03:16 -0800
--> RV10-List message posted by: "AirMike" <Mikeabel(at)Pacbell.net>
Per Ricksked if the engine is new you MUST use straight Mineral Oil per Lycoming's specs until "the oil consumption stabilizes". Get it from your local FBO C Spruce C or Chief Aircraft. Be sure to drain all of the preservative oil from the engine first.
OSH '10 or Bust
Q/B - testing phase 1
http://forums.matronics.com/viewtopic.php?p=281189#281189
Posted: Wed Jan 13, 2010 7:50 am Post subject: IO 540 motor oil? |
Finally got out to the Eci page- http://www.eci.aero/pages/tech.aspx#breakin
Sent: Tuesday, January 12, 2010 12:30 PM
To: RV 10 group (rv10-list(at)matronics.com)
Subject: RE: Re: IO 540 motor oil?
I spoke to Lycoming's Bart, He then spoke to the tech department. He said that the Cortec VC1-326 could be added to a 20w-50 mineral engine oil in a 1 to 10 ratio. I will be using a syringe to fill the two cylinders that lost the oil whan I removed the lower plugs.
[quote] Subject: Re: IO 540 motor oil?
From: Mikeabel(at)Pacbell.net (Mikeabel(at)Pacbell.net)
Date: Tue, 12 Jan 2010 11:03:16 -0800
OSH '10 or Bust
