AW: Fuel tank
r.twellmann(at)steute.com
PostPosted: Thu Jan 14, 2010 1:43 am    Post subject: AW: Fuel tank Reply with quote
When I started my 2-place project in 1994 I took a jar with avgas and a jar with mogas and put in small pieces of laminates from the materials supplied with the kit.
Over the years i refilled the evaporated fuel occasionally.
Now after more than 15 years the samples in the avgas jar do not show any change or degradation. But on the bottom of the mogas jar you can see
a lot of small chips and flocs and the parts look somewhat frayed on the edges.
This gives me the confidence that my epoxy covered tanks work fine (only) with avgas.
Ralf
Von: owner-kis-list-server(at)matronics.com [mailto:owner-kis-list-server(at)matronics.com] Im Auftrag von Scott Stearns
Gesendet: Mittwoch, 13. Januar 2010 18:51
An: kis-list(at)matronics.com
Betreff: Re: Fuel tank
Jeffco advertises that it's impervious to avgas. I doubt the epoxy makers would vow to that.
When I was at Scaled they had done tests of epoxy laminates that had been sitting in jars of 100LL for years. The final test was at 10 years if I remember right and there was no reduction in properties. Of course all epoxies are not excatly the same, but it bodes well.
Ethanol in Mogas is a disatster though.
Scott
--- On Wed, 1/13/10, Alfred Rosa <76papa(at)dishmail.net> wrote:
Subject: Re: Fuel tank
To: kis-list(at)matronics.com
Date: Wednesday, January 13, 2010, 3:50 AM
Is epoxy impervious to avgas, or is Jeffco better? Can Jeffco be somehow applied over epoxy in sealed tanks (sloshed maybe)?
Al
On Jan 13, 2010, at 12:13 AM, Scott Stearns wrote:
I used the Jeffco stuff in aircraft spruce. I squeeged in on then painted on two coats The factory airplanes just squeeged on normal epoxy. If I did it again I'd probably just use the normal epoxy and really work it in with a squeege. Maybe add a little flox. The jeffco stuff does make the insides of the tanks look nice through the fuel cap.
Scott
=nofollow target=_blank>http://www.matronics.com/Navigator?KIS-List
href="http://www.matronics.com/Navigator?KIS-List">http://www.matronics.com/Navigator?KIS-List
PostPosted: Thu Jan 14, 2010 4:44 am    Post subject: AW: Fuel tank Reply with quote
Ralf,
You can't ask for a better test than that. Thanks, that puts me at ease.
Al
On Jan 14, 2010, at 4:41 AM, Twellmann, Ralf wrote:
[quote] When I started my 2-place project in 1994 I took a jar with avgas and a jar with mogas and put in small pieces of laminates from the materials supplied with the kit.
Ralf
Von: owner-kis-list-server(at)matronics.com [mailto:owner-kis-list-server(at)matronics.com (owner-kis-list-server(at)matronics.com)] Im Auftrag von Scott Stearns
An: kis-list(at)matronics.com (kis-list(at)matronics.com)
