		gengrumpy(at)aol.com Guest
				 Posted: Fri Jan 22, 2010 7:15 pm    Post subject: Wheels, chocks and fiberglass |
				Just a note to the list, for whatever it's worth.
 Found my nose wheel flat today at the hangar (not sure why yet).
 I use the small, aluminum chocks with litening holes you can get from
 Srpuce and other supply houses.
 As the tire slowly deflated, the wheel pants settled down onto the
 chock.
 The top of the chock did a good job crushing the bottom of the front
 part of the nose fairing as the chock is wider than the tire.
 Now I have to do fiberglass repair and cut the chocks down so that
 they are no wider than the tire itself.
 You might check your chocks out to avoid similar headache in the
 future.....and remember this when you are parked on a transient ramp
 somewhere (I take my chocks with me).
 grumpy
 N184JM
		ricksked(at)cox.net Guest
				 Posted: Fri Jan 22, 2010 7:39 pm    Post subject: Wheels, chocks and fiberglass |
				Great tip Grumpy....not normally a concern for folks used to retracts
 Once you get pants you need to worry bout "PANTS ON THE GROUND" lol.....
				 Posted: Fri Jan 22, 2010 9:19 pm    Post subject: Wheels, chocks and fiberglass |
				Oh please Grumpy, can we get a picture?
 "Looking like a fool with your pants on the ground"
 Too FF
		Phil.Perry(at)netapp.com Guest
		Albert Gardner
				 Posted: Sat Jan 23, 2010 9:33 am    Post subject: Wheels, chocks and fiberglass |
				I had a main flat once and found that I couldn't jack the plane until I took
 the pant off but couldn't get the pant off because the lowest screws were
 Phillips and resting almost on the ground. Had to locate a wing jack to
 change the tire. After that I used short hex head screws in those locations
 so I could remove them.
 Albert Gardner
 N991RV
 Yuma, AZ
  _________________ RV-9A N872RV
RV-10 N991RV |
