DKrummel
Joined: 02 Nov 2008 Posts: 7 Location: Independence Airpark Oregon
Posted: Mon Jan 11, 2010 4:55 pm Post subject: Bungee discussion |
Sam - I am building an 801 and have questioned my EAA Tech Adviser on a different way to separate the elevator cables (and rudder cables) from rubbing together. He pointed out how ultra-lights have been avoiding the rubbing of controls cables since their inception by threading the cables through a piece of high strength, high density plastic tubing. A lot of ultra cables are complete encased in tubing - thus preventing any wear on the cable itself. He recommend placing the tubing where the cables cross paths. The tubing I.D. (inner dia.) should be slightly larger than the cable diameter.
There are three ways to anchor the tubing: 1) Where the tubing crosses and creates an "X" pattern, put two cable ties in the middle of the "X", one over the other in their own "X" pattern. This locks the tubes from moving up and down the cable. 2) Build a support bracket at the "X" and attach the center of the "X" on the bracket. And 3) (if your cables are not continuously in contact with each other) Secure the tubing onto the cable to keep it from moving, but use a long enough piece of tubing that when the cables do touch, the tubing is at that location (+ or - a foot or so). You will then get contact with the tubes - not the cables.
This sounds like it should work pretty slick and I hope to use it for my 801 when I get to that stage in the building process. My rudder cables will now have a more direct routing to the rudder horns without any slight "detours", as is their current path through the fuselage. Hope you find this helps.
Dennis Krummel N801DK
PS - I plan on using the hydraulic tubing. It is very strong and has good resistance to wear.
_________________ Fly Friendly - Fly Safe
Zenith 801 / Lycoming IO360 / MT 3 Blade Prop |
blackmore(at)platinum.ca Guest
Posted: Mon Jan 11, 2010 6:00 pm Post subject: Bungee discussion |
Try corelon ( spelling) truck air brake lines
[i]----
agibeaut
Posted: Mon Jan 11, 2010 7:27 pm Post subject: Bungee discussion |
Sounds like a good plan, but do yourself a favor and do nothing until you rig the elevator cables, and then experience what happens as you move the stick left and right. You'll understand at that point. Cables rubbing is a secondary issue. The primary issue (as pointed out by some else prior) is the fact that the cables are not centered on the torque tube and will tighten and loosen as the stick is moved right and left. You need something to take up the slack (bungey) or you will be chasing this forever. I chased it for 3 nites before I finally listened to the guys on this list. You need a device to take up the slack, and rubbing cables will be eliminated when you do that. Just trying to help guys, and share the mistakes I've made so you don't have to make them. Good luck.
--- On Mon, 1/11/10, dennkrumm(at)aol.com <dennkrumm(at)aol.com> wrote:
| Quote: | From: dennkrumm(at)aol.com <dennkrumm(at)aol.com>
Subject: Bungee discussion
To: zenith701801-list(at)matronics.com
Date: Monday, January 11, 2010, 6:09 PM
diameter.
the cables.
-----Original
Message-----
Sent: Sun, Jan 10, 2010 9:22 am
Subject: Re: Zenith701801-List Digest: 1
Msgs - 01/08/10
How are you keeping the elevater cables separated so they
do not rub and wear?
Sam
ggower_99(at)yahoo.com Guest
Posted: Tue Jan 12, 2010 10:35 am Post subject: Bungee discussion |
Nothig as simple and proven as the bungee cord...
Saludos
Gary Gower.
"Only add simplicity and lightness to an airplane"...
Date: Monday, January 11, 2010, 7:09 PM
cffd(at)pgrb.com Guest
Posted: Sun Jan 17, 2010 9:06 am Post subject: Bungee discussion |
I used a pulley on the cable and two springs (for redundancy) to pull the down elevator cable to the right. It is attached to the bottom gusset on the mid fuselage "L" frame.
Chuck D.
N701TX
ch701builder(at)yahoo.com Guest
Posted: Sun Jan 17, 2010 4:22 pm Post subject: Bungee discussion |
Hey Chuck,
Could you take a quick picture of your setup for us.
Keith
N 38.9940
W 105.1305
Alt. 9,100'
Scratch - Working on cabin area
Sent: Sun, January 17, 2010 10:05:14 AM
Subject: Re: Bungee discussion
Chuck D.
N701TX
