Dana
Posted: Tue Jan 19, 2010 11:00 am Post subject: Bing54 / Max height btw Fuel tank and Mikuni fuel pump |
At 01:19 PM 1/19/2010, Richard Girard wrote:
| Quote: | | ..."Another thing to remember is that the pulse pump is always limited to the pressures or pumping value of the crankcase. With a pulse pump it is nearly impossible to create too much pressure for the Carb float level... |
Almost correct... or correct if the proper float needle and seat are used. Gravity feed systems use a larger needle and seat. If a pump is used with the large needle/seat, the pump will push fuel right past the needle and the engine will flood.
-Dana
Can I deduct last years taxes as a bad investment? [quote][b]
