Emags
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> RV9-List
gbrasch(at)earthlink.net
PostPosted: Tue Apr 18, 2006 8:16 am    Post subject: Emags Reply with quote
This, from a friend on the Emag issue. Glenn in Arizona -9A finishing kit ordered.
-----Forwarded Message-----
Sent: Apr 17, 2006 5:49 PM
To: Glenn Brasch <gbrasch(at)earthlink.net>
Subject: Emags
You can forward this to your 9 list.
So far I have 55 hours of time on my Emag and Pmag system. The install was very easy. Hint here, install before the engine is on the airframe for even easier install.
I have not had any temperature issues at all. My only temp issue is with the oil and the method the oil cooler was mounted. No abnormal CHT or EGT issues.
I recommend that the timing be checked and make sure the programming switches are in the right positions.
I like them and would recommend the Emag Pmag system to anyone.
Not affiliated with the company, just a satisfied customer.
Darwin N. Barrie
Chandler AZ
RV-7 N717EE
ECI IO 360
- The Matronics RV9-List Email Forum -
http://www.matronics.com/Navigator?RV9-List
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> RV9-List All times are GMT - 8 Hours
