Dick Maddux
Posted: Sat Jan 23, 2010 8:43 am Post subject: Kiev Prop update |
Well, this is the last you will hear from me on this subject so I will quit boring you.
Yesterday was a golden day for flying. Temp was 70 degrees with 5 knots of wind down the runway (today is dog do do)
I did all my test flying on this prop. (6 hrs worth..prop on/off, change pitch,etc)) Here are the numbers:
KIEV PROP:
(1) 12 degrees pitch/4800 static/95-100 (at)5000 rpm/5500 full throttle
(2) 11 degrees pitch/5000 static/ 90(at)5000rpm/5800 ([email]90(at)5000rpm/5800[/email]) full throttle
(3) 10 degrees pitch/5200 static/80(at)5000 ([email]static/80(at)5000[/email]) rpm/ would have exceeded 5800 at full
Notes:
(1) Prop was much smoother running than the Warp, engine cooling seemed to be greater ( cht and oil temps),power on approach was 2800 to maintain 55 mph approach speed vs 1800 rpm on the Warp. Prop acted as a "flat plate". If pulled to idle the aircraft would come down much faster (not necessarily a bad thing..like going to full increase on a constant speed prop)
(2) prop pitch angles were based on the prop angle adjusting tool marks not actual prop pitch angles
WARP PROP:
(1) 5200 static-5400 down the runway/88-90 (at)5000rpm/5700 full throttle
CONCLUSION:
I really liked the beauty of the Kiev prop, but you just can't stand around and look at it. I loved its smooth running (like a turbine). The static rpm was way too low to achieve a meaningful speed increase for this prop. 5200 is the minimum per Rotax instruction.
I have gone back to my "butt ugly" Warp (as one guy called it).The prop is well built and I like the prop to flange attachment much better than the Kiev arrangement. The HP hub uses prop bushings on the outer holes for better stability I think.(LYC/Cont style)
As a side note I did sell the Kiev within 1 hour of me telling a guy at the Sebring Light Sport expo I did not want it. They are pretty backed up on orders at Kiev.
Oh Well !!! ... I sure wish it would have worked !!!!
Dick Maddux
Fox 4
912UL
Milton,Fl
dave
Posted: Sat Jan 23, 2010 9:41 am Post subject: Kiev Prop update |
Dick,
Great report on the Kiev although disappointing.
I would suggest IVO if you want more speed.IVo do look flimsy but they do work well.
I run mostly WARP as for seaplane it near indestructable although it heavier.
Dave
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube |
propellerdesign(at)tele2. Guest
Posted: Sat Jan 23, 2010 1:03 pm Post subject: Kiev Prop update |
There is some test of different props on
http://www.stolspeed.com/id/62?secondary_id=
Pic seems to be gone, but text is there.
it say about the same as your short test, not a big difference in cruise speed but in static rpm.
Bolly seems to be a snap better.
Jan
