bill.pagan(at)yahoo.com Guest
Posted: Thu Jan 21, 2010 7:05 am Post subject: Upgrade Kit Rivet Removal |
[img]cid:1264086095309(at)dclient.mail.yahoo.com[/img]
Hey all,
Need some advice on rivet removal. On the spar solid rivets, I've drilled the heads of the rivets and used a chisel to pop the heads off (just like in the videos). I center drilled a relief hole 3/4 or so through the rivet and the 9 rivets outboard of rib #6 came out pretty easily when I used my 3x rivet gun to drive them out. However, the rivets inboard of rib #6 where the spar cap doubles up I can't get the rivets to budge. I'm using a 3x rivet gun at about 100psi. I actually bent the punch I'm using in the rivet gun. Any advice is greatly appreciated. I'm really good at busting stuff and want to be especially careful here.
Bill Pagan
9.31 KB |
3090 Time(s) |
davgray(at)sbcglobal.net Guest
Posted: Thu Jan 21, 2010 9:23 am Post subject: Upgrade Kit Rivet Removal |
rwtaylorjar(at)HOTMAIL.CO Guest
Posted: Thu Jan 21, 2010 6:29 pm Post subject: Upgrade Kit Rivet Removal |
Bill C
Try using two C-clamps C nice and tight C 1 each side of the rivet.
Rob Taylor.
Date: Thu C 21 Jan 2010 07:03:51 -0800
Subject: Upgrade Kit Rivet Removal
To: zenith601-list(at)matronics.com; zenith-list(at)matronics.com
.ExternalClass DIV {;} [img]cid:1264086095309(at)dclient.mail.yahoo.com[/img]
Hey all C
Need some advice on rivet removal. On the spar solid rivets C I've drilled the heads of the rivets and used a chisel to pop the heads off (just like in the videos). I center drilled a relief hole 3/4 or so through the rivet and the 9 rivets outboard of rib #6 came out pretty easily when I used my 3x rivet gun to drive them out. However C the rivets inboard of rib #6 where the spar cap doubles up I can't get the rivets to budge. I'm using a 3x rivet gun at about 100psi. I actually bent the punch I'm using in the rivet gun. Any advice is greatly appreciated. I'm really good at busting stuff and want to be especially careful here.
Bill Pagan
Start searching NOW! Search for properties that match your lifestyle!
9.31 KB |
3065 Time(s) |
purplemoon99(at)bellsouth Guest
Posted: Thu Jan 21, 2010 7:10 pm Post subject: Upgrade Kit Rivet Removal |
Robert,drill a larger ID> hole in the rivit ,then you can drive them our with about 3 firm hits. worked well for me... Joe N101HD
Sent: Thu, January 21, 2010 9:23:55 PM
Subject: RE: Zenith-List: Upgrade Kit Rivet Removal
Bill,
Try using two C-clamps, nice and tight, 1 each side of the rivet.
Rob Taylor.
Date: Thu, 21 Jan 2010 07:03:51 -0800
.ExternalClass DIV {} [img]cid:1.2894822270(at)web180603.mail.sp1.yahoo.com[/img]
Hey all,
Bill Pagan
9.31 KB |
3064 Time(s) |
