top engine case bolts
indigoonlatigo(at)msn.com
PostPosted: Sat Jan 23, 2010 7:05 pm    Post subject: top engine case bolts Reply with quote
I was attaching the front and aft baffle brackets to the top of the engine case. These bolts are 7/16 diameter coarse thread.
The question I have is one C why are they undersize for the hole which they fill C second C why are they coarse thread C lastly C what is the torque value. I have the lycoming torque value pages that were put on this forum C but I couldn't find the specification for these bolts.
Regular value for a 7/16 is 50 LB/Ft. I snapped the first bolt I tried to tighten. I am believing that these bolts are very special and must be designed for expansion.
Anyone have the answers and another source or will I need to call Lycoming to order another bolt and get the torque value from them.
Thanks C
JOhn
Kelly McMullen
PostPosted: Sat Jan 23, 2010 8:01 pm    Post subject: top engine case bolts Reply with quote
Looks like the parts manual calls for LW25 in varying lengths for all
the parting line bolts, which is 1/4" bolt X20 pitch thread. The
manual calls for 75 INCH pounds. Not sure where you are finding 7/16
diameter bolts other than for the alternator mounting.
You can get engine bolts from most parts suppliers.
On Sat, Jan 23, 2010 at 8:02 PM, John Gonzalez <indigoonlatigo(at)msn.com> wrote:
The question I have is one, why are they undersize for the hole which they
fill, second, why are they coarse thread, lastly, what is the torque value.
I have the lycoming torque value pages that were put on this forum, but I
JOhn
Kelly McMullen
A&P/IA, EAA Tech Counselor
KCHD
PostPosted: Sat Jan 23, 2010 8:18 pm    Post subject: top engine case bolts Reply with quote
Thanks that's about everything I need
Appreciate it.
DO Not archive
Date: Sat C 23 Jan 2010 20:59:13 -0700
Subject: Re: top engine case bolts
--> RV10-List message posted by: Kelly McMullen <apilot2(at)gmail.com>
the parting line bolts C which is 1/4" bolt X20 pitch thread. The
On Sat C Jan 23 C 2010 at 8:02 PM C John Gonzalez <indigoonlatigo(at)msn.com> wrote:
> Thanks C
> JOhn
&gt===================
n801bh(at)netzero.com
PostPosted: Sat Jan 23, 2010 8:26 pm    Post subject: top engine case bolts Reply with quote
Ya know. I think he is assuming the head size of the bolt, 7/16" is the bolt size. A 1/4" bolt has a socket/wrench size of 7/16..... No wonder it broke at 50 ft lbs.
Ben Haas
N801BH
www.haaspowerair.com
Kelly McMullen
PostPosted: Sat Jan 23, 2010 8:49 pm    Post subject: top engine case bolts Reply with quote
If you haven't already, I suggest downloading the parts and overhaul
manual from Tim's site.
The bolts are on page 1-13 for the case parting line.
On Sat, Jan 23, 2010 at 9:16 PM, John Gonzalez <indigoonlatigo(at)msn.com> wrote:
Appreciate it.
DO Not archive
> Date: Sat, 23 Jan 2010 20:59:13 -0700
> From: apilot2(at)gmail.com
> To: rv10-list(at)matronics.com
> > engine
> > they
> > value.
> > I
> > to
> > Lycoming
> > Thanks,
> > JOhn
Kelly McMullen
KCHD
PostPosted: Sat Jan 23, 2010 8:58 pm    Post subject: top engine case bolts Reply with quote
I was about to make that admission C what was I thinking
Date: Sun C 24 Jan 2010 04:22:43 +0000
Ya know. I think he is assuming the head size of the bolt C 7/16" is the bolt size. A 1/4" bolt has a socket/wrench size of 7/16..... No wonder it broke at 50 ft lbs.
Ben Haas
N801BH
PostPosted: Sat Jan 23, 2010 9:12 pm    Post subject: top engine case bolts Reply with quote
For penance you need to say 2 our fathers, 3 hail mary's and log 2.4 PIC in the next two weeks. By doing that you will stay out purgatory... Or filling out FAA form 75747, which is alot worse then hell. <GG>
Ben Haas
N801BH
PostPosted: Sat Jan 23, 2010 9:40 pm    Post subject: top engine case bolts Reply with quote
Actually what is better is to retrace the thought process which led me down that path so that it doesn't happen again.
The repetitive nature of constructing the baffles lulled me into stupidity. Without plans to callout the size of the bolt C as is done with the building plans C my mind went into dumb mode.
Date: Sun C 24 Jan 2010 05:08:16 +0000
Subject: RE: top engine case bolts
For penance you need to say 2 our fathers C 3 hail mary's and log 2.4 PIC in the next two weeks. By doing that you will stay out purgatory... Or filling out FAA form 75747 C which is alot worse then hell. <GG>
Ben Haas
N801BH
PostPosted: Sat Jan 23, 2010 9:43 pm    Post subject: top engine case bolts Reply with quote
Where is it?
That good stuff used to be in the builders only section. I can't find that section anymore
JOhn
Date: Sat C 23 Jan 2010 21:46:52 -0700
If you haven't already C I suggest downloading the parts and overhaul
On Sat C Jan 23 C 2010 at 9:16 PM C John Gonzalez <indigoonlatigo(at)msn.com> wrote:
> Appreciate it.
> DO Not archive
>> Subject: Re: RV10-List: top engine case bolts
>> > engine
>> > they
>> > value.
>> > I
>> > to
>> > Lycoming
>> > Thanks C
>> > JOhn
&gt==============
Tim Olson
PostPosted: Sat Jan 23, 2010 10:13 pm    Post subject: top engine case bolts Reply with quote
I replied offline.
Tim Olson - RV-10 N104CD
John Gonzalez wrote:
Where is it?
JOhn
> Date: Sat, 23 Jan 2010 21:46:52 -0700
> > Appreciate it.
> > DO Not archive
> >> > engine
which
> >> > they
> >> > value.
forum, but
> >> > I
tried
> >> > to
must be
> >> > Lycoming
> >> > Thanks,
> >> > JOhn
