astills(at)cox.net Guest
Posted: Mon Apr 17, 2006 7:51 am Post subject: Door Pulls |
Thanks to all who answered my inquiry about the door pulls. I plan on using
a piece of aluminum bent ot the right shape and will
attach as suggested by others with some epoxy and small bolts. Didn't want
to cut an access hatch and got some good suggestions
for getting the nuts & washer inside. My doors have "adjusted themselves"
while sitting for the last year or so and are pretty tight
while pulling them closed so will take a door pull mounted firmly. Thanks
again for all the answers and suggestions.
Al Stills
N625AZ
paul.mcallister
Joined: 09 Jan 2006 Posts: 177 Location: Waukesha, WI USA
Posted: Mon Apr 17, 2006 2:03 pm Post subject: Door Pulls |
Al,
I used some U shaped aluminum, I seem to recall it might have been .5" x 1"
x .5", but to be sure I would have to go and check.
What I did was to cut a slot in the door frame (in the back corner area)that
was wide enough to slip one face of the U channel inside the door skin.
Once I have that done I then put Redux and flox on the surface and slipped
it in. I seem to recall that I held it in place with sheet metal screws
that had a hexagon head which allowed me to tighten them with a wrench. I
looks pretty neat and this method spreads the load to a fair area on the
inside of the door skin. I hope this all makes sense.
Paul
Posted: Mon Apr 17, 2006 6:42 pm Post subject: Door Pulls |
Paul,
Has the slot had a tendency to pull out at all. I understand how you did it
but thought that
would weaken the inside skin a little, especially with a little too much
pressure from someone
who just got in and started pulling.
Al Stills
N625AZ
paul.mcallister
Posted: Tue Apr 18, 2006 4:01 am Post subject: Door Pulls |
Alan,
Yes, the skin does tend to pull out a bit, but or far (400 hours / 2 years)
it hasn't been a problem. My doors are fairly tight, so it takes fair
amount of "pull" to get it to close.
Paul
Posted: Tue Apr 18, 2006 6:09 am Post subject: Door Pulls |
Paul
Thanks for the info.....Mine have become quite tight also.
Al Stills
N625AZ
2 wks to painting
