Battery replacement philosophies . . .Battery replacement ph
jonlaury
PostPosted: Thu Jan 28, 2010 10:56 am    Post subject: Battery replacement philosophies . . .Battery replacement ph Reply with quote
..... I never have problems starting. ( batteries x tie to start) ... Hi James,Thanks for your experience. Have you ever tried starting your 540 with just one 18AH Panasonic? If so, was it adequate?When I talked to a Panasonic tech, he said that the 18AH was not suited to do what I wanted. I did find a a PowerSonic 21 Ah that would put out 210amps for 10 sec duration and it also has a flame retardant case & 30 more cranking amps than the 18AH at the same weight and cost.Power-Sonic PSH-12180FR John
jbr79r(at)yahoo.com
PostPosted: Thu Jan 28, 2010 2:18 pm    Post subject: Battery replacement philosophies . . .Battery replacement ph Reply with quote
Hi John
To answer your question no I haven't because the system is not set up that way. I do have electronic ignitiion and that may help in the starting, but the engine spins rapidly with the 2 batteries. I'll keep the info and look into the power sonic before my next change
Jim
James Robinson
Glasair lll N79R
Spanish Fork UT U77
Sent: Thu, January 28, 2010 11:53:58 AM
Subject: Re: Battery replacement philosophies . . .Battery replacement philosophies . . .
